Old 03-19-2015, 05:51 AM   #1
Tv Booster Fuse for Antenna
Do any of you know where the fuse is for the Tv booster for the antenna? I have a 2015 Solera 24R. The light was on and working at one time and now it does not come on or work. Thanks
lwalkplumb is offline   Reply With Quote
Old 03-19-2015, 08:51 AM   #2
I'm not sure, but I think the booster may be on the same circuit as the main (12 volt) TV, which appears to be the first fuse in the distribution center panel (near the floor in the kitchen).
But...it may be easier to simply check all the fuses in both the distribution center and the battery control center (kitchen side of the stairwell).
The 12 volt testers - a probe with a light on it with a wire to an alligator clip - work well to test fuses. Attach the alligator clip to a good ground, then use the probe on each fuse. If you're not sure which side of the fuse is hot, simply test both sides. One side of the blown fuse will turn the light on, the other won't. Both sides will turn the light on if the fuse is good.
Dave
PS - It's also possible that the booster has it's own inline fuse...
DaveJordan is offline   Reply With Quote
Old 03-19-2015, 04:02 PM   #3
I have checked every fuse I could find. None blown, I have no power at switch by tv with 12 volt and cable to it. Yellow wire has no power and I don't know were it goes.
Old 03-19-2015, 04:11 PM   #4
Check the wiring diagrams posted here:
24R 2015 Wiring Diagrams
As I read them, the yellow wire should be coming from circuit 1 (Main TV) on the distribution center panel. Sounds like there's a broken connection somewhere, but that may be hard to track down!
Dave
Old 03-19-2015, 05:34 PM   #5
Found the problem, it was the first fuse in the box. Thank you for your help. I am trying to take a trip next week and think I need to slow down a little. Would have found the problem the first time around.
This will be our first trip in the new 24R. Can't wait to get on the road.
Old 03-19-2015, 06:01 PM   #6
Mikegjax's Avatar
You are going to like!!!!
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
antenna, fuse
