Old 05-04-2012, 09:29 PM   #1
2012 Solera
JamesR's Avatar
Tv/cable hook-up
Is it just me? The external cable connection in the rear utility compartment doesn't seem to be connected to the 'Ant/cable' cable that runs to the tv?
The antenna seems to work fine but no signal from the cable connection.
Anyone have a clue?
JamesR is offline   Reply With Quote
Old 05-04-2012, 10:25 PM   #2
Make sure the power switch for the antenna amplifier is off. This switches between the antenna and the external cable connection.
DavieBabie is offline   Reply With Quote
Old 05-06-2012, 12:19 PM   #3
2012 Solera
JamesR's Avatar
That's the ticket!
Thanks, it worked, it is different than my other RV which didn't have the same set-up.
Old 05-07-2012, 10:05 PM   #4
gb73071's Avatar
I have the same issue. Where is the antenna amplifier?
gb73071 is offline   Reply With Quote
Old 05-08-2012, 06:45 AM   #5
In my 2011 Solera, it is in the entertainment cabinet above the passenger side rear door near where the front TV power line enters.
Cajundjb is offline   Reply With Quote
Old 05-08-2012, 08:07 AM   #6
GM
bclemens's Avatar
If you have the side TV, its on the white plug that the TV plugs into. It has a 110v outlet, a 12v outlet and a small black button that is the antenna booster. Green light should be off.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
