Old 06-07-2015, 05:31 PM   #11
Originally Posted by jayvan View Post
Brian, that's what I have (a roof mounted sat dish). The problem is the roof top cable doesn't seem to transmit the signal although my meter says there is no break in the cable. I am plugging the receiver into the middle coax... As I tried to explain earlier (sorry if it wasn't clear), if I just run my own cable off the roof and through the window then all works fine (so I know it's not an equipment problem).
Well, I pulled the TV and did a bit more troubleshooting. It is the cable pre-installed for sat from the roof that is bad... Dang! One more thing to add to the list. I'm still happy with the RV, but after hitting about a dozen "small" issues (none of which would stop me from using the unit) it's beginning to feel not quite as thrilling...
Jayme
2016 Sunseeker MBS 2400S
Australian Shepherd Puppy (Dash)
My Camera, and a lot of Dreams
jayvan is offline   Reply With Quote
Old 06-08-2015, 07:47 AM   #12
GM
bclemens's Avatar
I would make sure that the dealer who install the sat didn't run their own wire. We no prep for roof top Sat, but this is pretty new for us. Did we install the sat from the factory or did the dealer install it?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-08-2015, 09:15 AM   #13
Brian, the sat dish was self installed (part of the problem? LOL. ) I went with sat since it was a cheap add-on to the household service and everything was on sale. And because I had noticed an unused coax receptacle just in front of the living room vent and assumed it was for sat which I thought would make the whole thing pretty darn easy. The coax cable going into the middle coax on the plate and coming from the roof is orange. Perhaps my assumption that the coax plug on the roof was for sat is wrong or perhaps it's not hooked up to anything. The over the air stuff works just fine so I know those cables are correct.
It's in the 90s here in Portland (hot for us!) so when I get the chance I guess the next thing to do is pull that coax receptacle and see what's connected to it if anything...
Jayme
Old 06-19-2015, 08:56 PM   #14
Well, got the sat/tv/cable problem all sorted out. I thought perhaps the sat. jack on the roof may not have been hooked up at the factory. Turns out it was. The problem is that literally none of the connectors on the cables were crimped. A newborn could have pulled the cables out of the connectors. Whoever was supposed to crimp the cables at the FR factory must've been asleep that day. So, $60 later for a decent crimper and new F connectors I had all the cable ends I had access to crimped and now everything works well. Obviously, I shouldn't have had to spend that money or devote as much time as I did to something that should have been done correctly in the first place (I know, I'm preaching to the choir). Oh, well. I'm getting better at climbing the ladder to the roof and laying down lap sealant.
Jayme
mount, tv mount
