Old 08-21-2015, 07:49 AM   #11
The chances of your 12v power plug failing are slim. Your problem most likely is a fuse. First, check to see if there is a fuse inside the plug itself. Most screw apart revealing a fuse if so designed. If it doesn't contain a fuse, then the EE's fused or circuit protectected that circuit from the 12v circuit panel. Look there.
If all appears to be in order, test that 12v socket for continuity.
Old 08-21-2015, 08:01 AM   #12
Looks like the problem is the inline fuse in the plug. Will replace. Thanks for all the input and help.
Jnkier is offline   Reply With Quote
Old 08-21-2015, 09:09 AM   #13
RedLdr1's Avatar
A quick and easy test of any 12VDC power point is to plug in your cell phone charger. If it works the power point is good....
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 08-21-2015, 12:11 PM   #14
Pod2Vibe's Avatar
My 12VDC Jensen 32" LED plug overheated and died on a camping trip.
Replaced with a better quality 12VDC plug and cable that I had for another device.
No more issue.
The one that comes with the Jensen is not the greatest...
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-21-2015, 07:25 PM   #15
No more issue.
Good advice, I agree.
jdyson
(former owner, went back to Class A)
(but enjoyed our brief 'experiment' in downsizing!)
'16 Forester MBS 2401R
Hellwig 7254, TireMinder A1A & Sumo Equipped
jdyson is offline   Reply With Quote
Old 08-22-2015, 10:34 AM   #16
Originally Posted by Jnkier View Post
My tv just went out, checked the fuse box and everything looks ok. The plug red light is out so either the plug is bad or the socket is bad. Anyone have a solution? Thanks.
The power plug over heated and blew the inline fuse. Tried to get a replacement at Radio Shack but now would fit. Resorted to ordering one from Jensen. Plug was $10 shipping $12. Oh well should receive it in a week
Old 08-23-2015, 08:36 AM   #17
When you get the new plug, I assume they will send both sides, male and female. Be sure to change both out, noting if you see any wire burn etc. It's odd that one of those fail, but you want to swap out both sides to eliminate any problem in the socket. Just sayin'
Old 08-23-2015, 03:48 PM   #18
Pod2Vibe's Avatar
My Jensen plug overheated but did not blow the inline fuse.
It deformed the plug so much that it no longer has continuity to the socket.
Keep an eye on your new one and check it for heat after an hour or two of TV use, just in case.
Pod2Vibe
Old 08-23-2015, 04:26 PM   #19
Will do thank you!
Old 08-23-2015, 04:41 PM   #20
Most 12 v plugs have fuses in the end of them.
power
