Old 02-04-2016, 08:47 AM   #1
Upgrade hitch receiver
I would like to carry 2 scooters, about 200# each the carrier 100#. The carrying capacity on my hitch receiver is 350#. Has anyone had a new receiver installed that will carry more weight? I don't want to use a trailer. My MB Solera is 24". Any ideas/advice would be appreciated!
Karter is offline   Reply With Quote
Old 02-04-2016, 02:08 PM   #2
The next class up is; Class 4 (Class IV) trailer hitch Trailer hitch with weight carrying rating of up to 10,000 lbs gross trailer weight and 1,000 - 1,200 lbs tongue weight. Although many times any hitch with a capacity greater than 5,000 lbs gross weight is referred to as a class four. Also, check the labeling stamped into the hitch to make sure it is a 350# tongue wt.
Best bet would to spec it for the sprinter so it bolts up. Like these; Sprinter Hitch: Towing & Hauling | eBay
Just dbl check on tongue weight rating, because the farther you get away from the receiver, the greater the mutiplier on tongue weight.
Old 02-06-2016, 02:26 PM   #3
GM
bclemens's Avatar
Don't forget that doing it that way takes 500 lbs right off your carrying capacity..which is not a ton to start with on a Sprinter chassis.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-08-2016, 10:41 PM   #4
MNtraveler's Avatar
Are you referring to the 2 x 200# plus carrier 100# = 500#? Because that's the added cargo weight. But there would also be additional weight by moving to a higher capacity receiver hitch (new hitch weight less old hitch weight).
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-09-2016, 08:24 AM   #5
I am more confused than ever. Here is what I have come up with. Purchase Swivelwheel 46. Two scooters at 200# each on Swivelwheel 46. No problems correct?
Old 02-09-2016, 08:53 AM   #6
GM
bclemens's Avatar
Sort of.
The issue is dead weight. While you can tow 4220 (on the ground), anything you hang from the hitch (dead weight) is just like carrying fresh water or cargo, it goes against the GVWR of the vehicle (11,030 lbs total) and not the GCWR (15,250).
If you have 1000 lbs carrying capacity on the Sprinter and you have 500lbs of scooters and hitch, that only leaves you 500 lbs for people, cargo, water.
If you put all that weight on a trailer....only 10% typically transmits to the hitch. With a swivel wheel...I'm not sure what they figure in...but I'm guessing its more than 10%. More like 50%. If the hitch and scooters weigh 600lbs, then 300 may count against cargo. I would verify this with the swivel wheel mfg.
Old 02-09-2016, 09:07 AM   #7
AquaMan's Avatar
With a 350# hitch tw, you could possibly pull a 3500# trailer giving that a 10% tw. Well within the realm of what you are wanting to do
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-03-2016, 09:55 AM   #8
ilmor's Avatar
A better idea would be to get a dual motorcycle trailer to tow them.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 06-04-2016, 08:37 AM   #9
I tow a 6x12 enclosed and its weight is around 1000 empty no load scooter, bikes, ladders, chairs etc. in it and the tongue weight is less than 200 lbs.
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
hitch, upgrade
