Old 05-13-2015, 12:57 PM   #1
Walking On 24R Roof
Is there a recommended way to walk on a 24R roof to install a cover over the RV for storage? Is it best not to walk on the roof?
CASolera is offline   Reply With Quote
Old 05-13-2015, 01:18 PM   #2
Mikegjax's Avatar
You can walk on the roof. I am not to steady on my feet so I use good quality knee pads and crawl around up there. The roof is very strong and I have not had any problems. Been up there many times.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-13-2015, 02:55 PM   #3
Pod2Vibe's Avatar
I concur, just don't use Home Depot brand Husky knee pads with slick plastic caps on them!
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 05-13-2015, 03:57 PM   #4
I was up last week to replace the king TV antennae I broke under a tree on cape Hatteras. I thought the limb would give way but the plastic did first. $150 lesson. I'm thinking of mounting a couple of forward and rear facing cameras up there and tie them to the rear camera. Any thoughts. That way I can see clearance much better.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 05-13-2015, 06:53 PM   #5
Mikegjax's Avatar
Erwin makes a good set of pads!
2014 Solera 24R
USN Retired
Old 05-14-2015, 11:57 AM   #6
24R
A cover will void. the paint warranty, full paint only
northdakota is offline   Reply With Quote
Old 05-14-2015, 12:02 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Walking on the roof
Nothing wrong with walking on the roof.....just watch where you're stepping. Also,,,,,if you feel a soft spot, avoid stepping there. It could be a weakness in the superstructure of the roof or a rot-spot from water leaks.
Grampa Jim is offline   Reply With Quote
Old 05-14-2015, 07:15 PM   #8
hkreck's Avatar
Where you see that part about the warranty issue?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 05-14-2015, 08:12 PM   #9
24r
I have a sunseeker 2400w, it was in the owner packet.
Old 10-18-2015, 10:04 AM   #10
So if a cover voids the full body paint warranty do you recommend not covering it during the winter?
Solera Scott is offline   Reply With Quote
roo, roof
