Old 07-21-2015, 03:18 PM   #11
Mikegjax's Avatar
That should work.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 07-21-2015, 04:08 PM   #12
Ecopco's Avatar
Originally Posted by JLeising View Post
Hence the trick noted above of taking the outside shower hose and running it over to the gravity fresh water fill point. As you state, water is pumped into the RV water system, out the shower hose, and into the fresh water tank. While I haven't done it, sounds like a neat trick!
That's the kind of ingenuity that got Apollo 13 home!
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 07-22-2015, 10:45 AM   #13
I don't have an outside shower in my 2011 Georgetown 327DS but have done the same thing using my water hose and a faucet to hose adapter. The water pump pulls in water from a jug, through the winterizing hose; pressurized water flows out the bathroom sink, through the water hose, and finally into the fresh water fill port for the water tank.
When I dewinterize, I always make sure to also flush the antifreeze input area in case I need to use this technique to fill the water tank.
Phil
pmsherman is offline   Reply With Quote
Old 07-23-2015, 03:51 PM   #14
Quick Connect Spray?
No outdoor shower on my '13 24R, but there is a sprayer and quick connect. If I had a male QC adapter to fresh water hose I could run the hose around to the tank fill and do it that way.
There seem to be more than one type of hose QC. Does anyone know what type of QC connector I need that would be compatible with the stock connector on my '13 Solera 24R?
gfior is offline   Reply With Quote
Old 07-23-2015, 07:24 PM   #15
Mikegjax's Avatar
Do you have the coiled hose?
2014 Solera 24R
USN Retired
Old 07-24-2015, 03:08 PM   #16
Sprayer
Yes, but I want to attach a longer potable water hose to reach across to the tank fill, so wanting to buy a compatible QC male adapter.
Old 07-24-2015, 04:00 PM   #17
Mikegjax's Avatar
If you take the nozzle of a regular hose will fit.
2014 Solera 24R
USN Retired
water
