07-20-2015, 04:01 PM
Water fill in a primitive situation?
Quoted from a post on the Winnie list:
<<You can fill your water tank by using the antifreeze siphon hose. I think you set one valve to "tank fill" and the other one to "winterize", put the hose in a jug of water and turn on the pump.>>
Can this be done on the Solera?
07-20-2015, 05:03 PM
No.
2014 Solera 24R
USN Retired
07-20-2015, 05:16 PM
Just hook a hose to the fresh water tank fill then put a funnel on the hose a fill it. Might be easier with 2 people so someone can hold the hose and funnel while you pour the water in.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
07-20-2015, 05:22 PM
Not sure on the solera, but I've done this on my Sabre fiver many times. Anti freeze pickup hose stuck in portable water tank (I use collapsible 5 gallon containers), outside shower head removed, and hose stuck into fw fill port (if you have a hose hookup for the full port, you'll need to affair the end of this hose to garden hose threads), and then, with pump in, turn winterizing valve to winterize, and turn on outside shower cold water.
Seems complicated until you've done it.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
07-20-2015, 05:35 PM
2012 Solera 24S
Read this thread:
http://www.forestriverforums.com/for...ion-59388.html
07-20-2015, 10:04 PM
i went out and just purchase a 12 volt transfer pump i hook it to my 40 gallon extra water tank and run the hose to the tank fill. the pump runs 3 gallons a minute. and it only cost me 40 dollars. can be found at any farm fleet store.
so when I am low on water I put the extra tank in back of truck drive to the nearest water fill and fill my tank up and drive back to camper and hood by transfer pump up and were done.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
07-21-2015, 09:02 AM
Haven't tried it but the way it pulled in the antifreeze I'm satisfied it will work.
You might have to prime it if the pump is totally dry.
07-21-2015, 09:22 AM
Racin
x2
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
07-21-2015, 01:40 PM
Don't think so. The winterizing valve is in the outlet side of the tank. When you use it anti-freeze is drawn in with the pump and sent out to the rv. If you use another container and use the winterizing hose, fluid would be taken from the container to the rv water system and not the tank. IMO.
2014 Solera 24R
USN Retired
07-21-2015, 01:47 PM
2012 Solera
Hence the trick noted above of taking the outside shower hose and running it over to the gravity fresh water fill point. As you state, water is pumped into the RV water system, out the shower hose, and into the fresh water tank. While I haven't done it, sounds like a neat trick!
JLeising
2012 Solera "S"
Calif SF Bay Area
07-21-2015, 03:18 PM
That should work.
2014 Solera 24R
USN Retired
07-21-2015, 04:08 PM
That's the kind of ingenuity that got Apollo 13 home!
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
07-22-2015, 10:45 AM
I don't have an outside shower in my 2011 Georgetown 327DS but have done the same thing using my water hose and a faucet to hose adapter. The water pump pulls in water from a jug, through the winterizing hose; pressurized water flows out the bathroom sink, through the water hose, and finally into the fresh water fill port for the water tank.
When I dewinterize, I always make sure to also flush the antifreeze input area in case I need to use this technique to fill the water tank.
Phil
07-23-2015, 03:51 PM
Quick Connect Spray?
No outdoor shower on my '13 24R, but there is a sprayer and quick connect. If I had a male QC adapter to fresh water hose I could run the hose around to the tank fill and do it that way.
There seem to be more than one type of hose QC. Does anyone know what type of QC connector I need that would be compatible with the stock connector on my '13 Solera 24R?
07-23-2015, 07:24 PM
Do you have the coiled hose?
2014 Solera 24R
USN Retired
07-24-2015, 03:08 PM
Sprayer
Yes, but I want to attach a longer potable water hose to reach across to the tank fill, so wanting to buy a compatible QC male adapter.
07-24-2015, 04:00 PM
If you take the nozzle of a regular hose will fit.
2014 Solera 24R
USN Retired
