Old 02-18-2014, 09:26 AM   #1
Lcblick's Avatar
Water Filter
Sorry if this has been posted already but I didn't see a specific answer. I want to replace the water filter under the Bed in my 2013 Solera 24S. When I winterized it, I pulled the filter out but the brand/specs are not listed on there. Any help would be appreciated.
Thanks...
Lcblick is offline   Reply With Quote
Old 02-18-2014, 10:10 AM   #2
cat1956's Avatar
Go to The Water Pur Company wed site. You should be able to identify which one you need.http://waterpur.com/html/waterpur_filters.html
cat1956 is offline   Reply With Quote
Old 02-21-2014, 08:20 AM   #3
Taylorgso's Avatar
I've never used the supplied onboard filter. I prefer to use the inline filter that can be connected to the outside water inlet. That gives me a better indication of the condition of the filter itself, requires no special tool, and doesn't require doing all sort of contortions to check/change the onboard filter. Also filters water before going into the fresh water tank, removing any spores etc., that may be in the campground water, and can grow inside the FW tank.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 02-21-2014, 08:46 AM   #4
mark0224's Avatar
Got ours at Lowes just took the old one with me and compared them. For the most part they are all the same size and it just depends on what you want it to do. At the beginning of the season I flush everything out, before putting the filter in. I then put some clorox and water in the water tank and flush all the lines again. Most campgrounds have chlorinated water and if they don't they have to be checked to make sure that the water supply isn't contaminated. More than likely if you get something in your water supply it will be from your hose. Make sure and drain them good doesn't hurt to put a little clorox through the hose and work it through till you smell it coming out the other end.
mark0224 is offline   Reply With Quote
Old 02-21-2014, 09:51 AM   #5
hkreck's Avatar
Ed
What inline filter are you using? That sound like a good idea over getting into the filter canister under the bed.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 02-24-2014, 06:53 PM   #6
Taylorgso's Avatar
Originally Posted by hkreck View Post
Ed
Henry: Darned if I can tell you right now. I threw away the boxes! Best I recall, I bought a couple of them online on sale and I can't remember where! Here's one available on Amazon.com that looks identical.
Culligan RV-800 Level 1 Recreational Vehicle Water Filter - Amazon.com
Greensboro, NC
Old 02-24-2014, 06:55 PM   #7
Taylorgso's Avatar
Mark is right. If you use the inline filter I mentioned, be sure and connect it between the hose and your coach. (Hoses have been known to get cruddy!) I fashioned a short (1' long) hose to make the connection between filter and coach).
Greensboro, NC
Old 02-24-2014, 07:10 PM   #8
hkreck's Avatar
Ok guys, thanks for the info.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 02-24-2014, 07:44 PM   #9
One of the first things I did on our 2014 24R was remove the filter. It is prone to breaking and flooding the MH if you forget to dump it and the weather turns cold. I replaced it with a 6" 1/2" brass pipe nipple. I filter the water at the inlet if necessary.
Mike
MikeA is offline   Reply With Quote
Old 02-24-2014, 07:48 PM   #10
hkreck's Avatar
Mike
Would it be possible to get a picture of you mod?
Henry & Tena
2013 Solera 24S
The Great Escape
water, water filter
