Old 03-22-2014, 07:42 AM   #1
water heater
2014 Solera R
Would someone please give me an idea as to how long it takes to generate hot water via the hot water heater using propane with outside temp at 40 degrees (inside temp was 67)?
I understand it would be less using electric. Is that true?
Tried heating water for first time the other morning. Had it heating for about 45 minutes and got luke warm for about 2 minutes before turning cold.
Thanks in advance.
kidagn11 is offline   Reply With Quote
Old 03-22-2014, 07:57 AM   #2
Somewhat right of center
Crabbyguy's Avatar
I'm usually have hot water within a half hour after heating with propane or electric. Using both about 20 minutes.... BUT that was during the summer.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 03-22-2014, 08:02 AM   #3
Oakman's Avatar
It sounds like your water heater is still in bypass for winterizing.
Sent from my NX008HD8G using Forest River Forums mobile app
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-22-2014, 08:07 AM   #4
fonzie's Avatar
X2, make sure it is in summer position as shown in picture...
Fonzie
Old 03-22-2014, 08:07 AM   #5
wmtire's Avatar
X2, you need to check your bypass valves to see if they are still set for winter (very common).....................and another thing to check is to see if your indoor or outdoor shower faucets are both turned on at the tap, but shut off with the valve on the shower wand. This also allows cold water to mix in with the hot, and some people forget they turned on the shower taps when draining the water out for the winter.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-22-2014, 08:18 AM   #6
Ford Idaho's Avatar
Outside shower?
Are the faucets open but the shower head closed?
Old 03-22-2014, 04:44 PM   #7
As others have said, definitely check your bypass valves on the water heater. Likely the in and out valves are open, or you would get no hot water. However, the bypass valve between the in and out is likely open also. That needs to be closed. Hot water coming out of the heater is mixing with water "bypassing" the heater--thus hot for a moment, then lukewarm at best.
To answer your other questions, propane heats faster than electric. Propane about 20 minutes. Electric maybe 30. You can use both to get the water up to temp faster. The main reason for using electric is that it is "free" with the campsite. Propane you pay for.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-22-2014, 04:52 PM   #8
Just be DARN sure there is water in the tank before using the electric heater. The element will burn out in only seconds if the tank is dry. Second consideration is 30 amp vs 50 amp service. The electric heater will pull around 11 amps by itself. And you won't be in control of when it comes on. So in a 30 amp site, you could easily trip the breaker by running the AC or a microwave or a space heater, etc; while the electric water heater is turned on.
Thus I never use the electric water heater -- just propane. Ours will be hot enough for a shower in 15 minutes or so... pretty fast!
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 03-22-2014, 04:56 PM   #9
x2 on making sure you have water in the tank. Even on propane, the electric element will fry if there is no water in the tank, just might take more than the five seconds if you turn electric on without water.
Don't see the concern with using amps. We have 30 amp service and can use everything at once. My readout on the energy management system does get real close to 30 when everything is going, but have never popped a breaker.
Old 03-23-2014, 05:36 AM   #10
Mikegjax's Avatar
I run everything plugged into 30 amps. AC, frig, coffee pot, water heater both tv's (DC), and have not popped a breaker to date.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
heater, water, water heater
