Old 06-08-2014, 07:18 PM   #1
Water Heater Story and Question
The wife and I were on our way home from a two week trip too Montana when we pulled into a RV park for the night at about 10pm in Sioux Falls SD. Hooked up water, power and waste went inside ran hot and cold water to clear air from lines, turned on A/C let bed down and climbed in. Went right to sleep but was awaken to the smell of something burning, jumped up and turned off the A/C thinking it was shot. Started looking and sniffing around to try and find what was burning, and discovered that it was coming from the Water Heater on the inside under the sink but not on the outside of camper so I killed the power too it turned the A/C back on made sure nothing was still burning and went back to bed. The burning smell was not really electrical; it smelled more like hot brakes. Today after getting home I go out to see if I can find what happened, everything looked ok couldn’t see any burn spots or anything. So I turn the power on and let it heat up I could get a faint smell to come from around the w/h but nothing like the other night, no smoke and no hot wires, the little control box that is tied to the w/h didn’t get hot or smell, that’s what I was thinking got hot. Now I have a feeling that I had a Hi-temp switch to stick and caused the tank to get hot enough to maybe start to melt the Styrofoam shield can’t and want be able to see the Styrofoam next to the tank until I pull the w/h unit. Has anyone had a w/h unit to do anything like this? Like to run things like this by all of you before I just tear in to it, there is a wealth of knowledge and experience here that I can’t thank you enough for.
pinkstonj is offline   Reply With Quote
Old 06-08-2014, 07:39 PM   #2
Ford Idaho's Avatar
Did you open the pressure relief and vent the air from the tank before you went to bed?
The tank may not have been full if you did not.
Old 06-08-2014, 07:57 PM   #3
Would not runing the hot water at the kitchen sink do the same thing?
Old 06-09-2014, 07:12 AM   #4
Loefflerh's Avatar
Even when the hot water boiler is not filled it should not smell....
How do I know? came home fom a trip -boiler still on. Removed the Anode and let water drain out....2 weeks later connected power to the rv to charge battery forgetting that the heater is still on.
Strange thing is heater is still working. I think it is taking longer to heat up so the heater element most probably has some damage and I have to replace it.
Hans
Loefflerh is offline   Reply With Quote
Old 06-09-2014, 07:32 AM   #5
Ford Idaho's Avatar
There would still be air in the top of the tank this will allow the heater to boil and that may be the cause of the smell.
Your house water heater the hot water comes out the top so opening a tap is fine, the water from the water heater in you trailer comes out just below the top.
Old 06-09-2014, 07:36 AM   #6
KyDan's Avatar
The water heater probably plugs into an outlet on the rear of the tank area.
I'd check that outlet and wires going to the back of that outlet and the power cord that's plugged into
that outlet and the other end of the power cord where it hooks to the
WH.
Hot brakes and hot wires smell a lot alike.
My -guess- is poor connection somewhere in the system near the
water heater did it.
Keep looking!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 06-09-2014, 08:13 AM   #7
Herk7769's Avatar
Look inside the outlet box the water heater plugs (or is wired) into.
My guess is the AC wires might be melted due to a poor (loose) connection that overheated.
This is a dangerous situation if it is the cause of your odor and needs to be investigated BEFORE you re-apply power.
HAM CALLSIGN - KC3FFW
Old 06-09-2014, 09:04 AM   #8
Thanks for the replies. Guess Iím on the right track with something in the wiring somewhere, it will be a few days before I can really look at it. Will post what I find.
Old 06-17-2014, 08:11 PM   #9
Well I found no burnt wires, but I did find that the Hi limit thermostat had burnt causing the circuit to be stuck closed causing the W/H to overheat. Have to get a new thermostat replacement part # 232306. Online piece is anywhere from $11.31 up to over $33, Iím going to check with my local RV supply store, if they are close will get from them (need to help the local folks).
heater, water, water heater
