Old 01-27-2014, 01:50 PM   #1
Water leaking
When the water pump switch is on water is flowing out the city water inlet. This started on the last leg of our trip. Any input would be appreciated.
2012 Solera
jcinca is offline   Reply With Quote
Old 01-27-2014, 02:01 PM   #2
fonzie's Avatar
Your city water inlet has a check valve internally, remove screen and see if it is stuck open.
where is the 'city water check valve'
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 01-29-2014, 08:04 PM   #3
Water leak
Thank you! I put the screen washer in backwards after cleaning it and that recessed the check valve. My bad.
Thanks again,
2012 Solera
leak, water, water leak
