Old 09-02-2014, 07:54 AM   #1
Water Pressure
When I am hooked up to city water my water pressure is not very good at the kitchen sink and shower. When not hooked to city water and using the water pump we have good water pressure. We do use a pressure reducer when hooked to city supply and the reducer seems to be working as it should. Any suggestions as to what is causing this.
Thank You
BadBob
BadBob is offline   Reply With Quote
Old 09-02-2014, 07:56 AM   #2
TURBS's Avatar
It's possible your back flow valve is stuck at the city water inlet.
Have you tried city water "without" pressure regulator?
TURBS
"SABRE OWNERS UNITED"
Old 09-02-2014, 08:16 AM   #3
No back flow valve on the city water outlet.
Thank You
BadBob
Old 09-02-2014, 10:38 AM   #4
Check screens on both faucets for debris.
13larry is offline   Reply With Quote
Old 09-02-2014, 07:25 PM   #5
Checked all the screens all clear and have good pressure when using the pump. Leads me to belive must be my pressure regulator.
Thank You
BadBob
Old 09-02-2014, 07:58 PM   #6
Kaadk's Avatar
Adjustable regulator or the $4-6 one they show and/or provide when you first bought the trailer? The cheap ones are just a pressure reducer, so if you've got already low enough pressure it'll just lower it even more.
That's why I'm in the market for a good adjustable one. Something I can dial in instead of being at the mercy of a basic reducer.
There's no use crying over spilt milk, unless it's on your keyboard.
pressure, water
