01-03-2012, 01:43 PM
jlfletc,
sorry to hear about all of your problems. In a way that is what prevented me from buying from a dealer far far away....
A/C Heat Pump - you need to either run the generator or have shore power for it to work - plus the heat pumpt ONLY works if it is more than 30F outside consuming a lot of power (and generating bad noise so you can't run it at night on most campgrounds).
To your manual problem, it will be VERY difficult to write a manual for any RV due to the extremely low volume they sell. Your dealer should have done a nice walk through explaining everything (ours did until my wife and I were comfortable with the explanations). I found the manuals useless to some extend except when looking in to replace pieces in the future.
Let us know what your local dealer as the root cause of the problem.
Reiner
2011 Solera
01-03-2012, 02:22 PM
jlfletc
Reading all the post and seems that since your water pump is still drawing air, would it be a possibility that there is not enough water into the fresh water tank? The suction line is not right at the bottom of the tank. Does your indicating level light show at least 2/3 full?
Fonzie
2011 Rockwood 8319SS with ProPride 3P hitch
2008 F250 Lariat CC SB 6.8L V10 4.10 axle ratio
Yamaha 3000iseb generator: Eastern Ontario
2011 stats:5 trips-21 nights camping
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 571 |
| 93 members and 478 guests |
| 3 Husker Drips, 4-2-6, 4bnabird, AgentSmith, Al Fresco, Barney1, bikendan, Bill_C, bouldercamper, bradyashton, Cafjackracing, Canuck_Doug, caper, cbj, chadvc, cpope84, cyclepuck, dashonthedash, dasimser, david-o, daw592, dawg82, ddemme, DGrissom, Dodge Guy, DonG, donn, dware1962, Elidh, etbt1216, f1100turbo, Fire Instructor, Fitchy, FLBBQMAN, FreedomTracker, frfan, GASPEDDLER, Go Camping, Hilgy, Iggy, imabmwnut, Indy Steve, JamesR, jd-ford-hd, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jrat, jsutherl, KKapa, kvn4th, kz08h5, lami, LeonFournier, lowbubba, low_flyer, lurch, MAT8970, MikeFletcher24, Mpjduff, Msaunders, mtofell, N3HCP, nailit, Namchief, newtsx3, nightcrawler, nrcamp, pappcam, pbrackney, pchrcane65, polkatronron, PrairieBoy, racerx, RalphieG, Rebel702, RichardE, Rsgtivr6, seatosea, snjparham, softwarejoe, stevengb, Swinks, tabkld93, Terier, Triguy, troyt, unhcharger25, wingriders, wvfireboss |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
