Old 05-26-2013, 01:19 PM   #1
Robert Mayberry
Water pump
Here we go again. The dealer has replaced my water pump three times due to its coming on for a couple seconds about every minute. They have checked for leaks. I have checked for leaks. There are none.
Every time I get a new pump it works well for a few months and then starts doing it again. I was just on a one month trip and it worked great the whole time. Then I drove to Los Angeles last week and it started again.
This is so frustrating.
Anybody else have this problem?
Bob
San Francisco
2011 Solera
robertmayberry is offline   Reply With Quote
Old 05-26-2013, 02:41 PM   #2
Twisty's Avatar
What brand/model pump is it? Maybe you got into a defective manuf. run.
OR has there been different kinds used?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-26-2013, 02:49 PM   #3
B47
Bob
San Francisco
2011 Solera
It might be that the pressure cutoff switch is either defective or needs adjusting, however you say that one than one pump causes the same problem so that might be a remote possibility.
You might have a leak that is difficult to source - is there any water on the ground under your unit?
B47 is online now   Reply With Quote
Old 05-26-2013, 02:50 PM   #4
B47
I meant to say that more than one pump - sorry.
Old 05-27-2013, 05:12 AM   #5
I really have no clue in this one either. Pump works for a few months, then it starts to do this - do you keep it on all the time? If you are hooked to city water, the pump should be turned off.. You probably already know that, but it was something I didn't for awhile. I'm sure someone here can help.
DebbieMH is offline   Reply With Quote
Old 05-27-2013, 05:45 AM   #6
Herk7769's Avatar
Rule out:
1) water leaking from your outside city water inlet
2) leaks at the outside shower
3) leaks at fittings in the camper
Then you must look at the water source.
If you are using a well to fill your fresh water tank, fine silt may be clogging/eroding the check valves in the pump causing pressure to leak back into the fresh water tank. This will cause regular cycling of the pump.
My suggestion is on your next pump (this one may be shot again) to put a high micron filter between the sand (screen) filter and the pump itself.
OR
Buy a high micron filter for your fill hose.
Completely drain your fresh water tank and flush it out with LOTS of FILTERED water.
Replace your inlet screen filter and pump (again - sorry).
Fill ONLY with filtered water from that source in the future.
HAM CALLSIGN - KC3FFW
