08-22-2011, 05:38 AM
Weak Electrical System
OK, does anyone else experience this?
If we are running the A/C, turning on the microwave will trip the breaker inside the coach.
Yesterday we were running the A/C, and if we turn on the electric hot water heater, it trips the breaker where we plug in outside. This happened in two different campsites.
Shouldn't a 30A system be able to handle more than just running the A/C? I'm sure that my past coaches were able to, or so I recall...
It's awfully annoying to have to turn the A/C off everytime we run the microwave. Also, not being able to use the A/C and the electric water heater at the same time doesn't make much sense.
2009 Forest River Solera
08-22-2011, 06:26 AM
too fast turbo sled
Some times park electric is not up to par. If its hot out and the whole park is running their air you may only see low voltage. 105 v. And less than 30 amps
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
08-22-2011, 06:53 AM
If its a 30A breaker, theoretically, it will only pop if my motorhome is using in excess of 30A. It would not matter what the rest of the campground is doing, or how hot it is, would it?
08-22-2011, 07:23 AM
true, but with lower voltage comes increased amps to do the same amt of work.
the breaker may be weak. i can run hw heater, frige, lighting, microwave, and one air conditioner on a 30 amp connection. usually if i do trip something, it is the campground breaker.
if it is one of the breakers in the trailer, it may be weak especially if it happens at different campgrounds.
that does seem to be a small amt of items to trip the 30 amp breaker. may try replacing that and see what happens.
08-22-2011, 07:33 AM
the breakers in my trailer appear to be made by cutler-hammer. they are sold at home depot but it looks like the price is fairly uniform where ever u go. seems like mine are type BP. take ur old one and compare. the buss contact slit is longer and the contact fits a slightly thicker buss.
08-22-2011, 07:47 AM
too fast turbo sled
I would say its a service issue at the camp ground only way to tell is to check there service with a meter.
Ron and Amy Benhart
08-22-2011, 07:56 AM
too fast turbo sled
We had this same issue a few years back a group of us were camping on hot day in late July.
Our breakers kept popping.
we later found out we were at the end of the line and had 20 campers ahead of us..... on the same 30 amp service. We later checked voltage and found we were only receiving 108 volts.
Ron and Amy Benhart
08-22-2011, 10:11 AM
So if I use a 50A receptacle with an adapter might it resolve this issue?
08-22-2011, 10:38 AM
i'd say check the a/c voltage inside the camper and see what u have. that should tell u what direction to take.
if they ran the the 50 off the same cable as the 30, i wouldn't expect it to solve ur problems. if they ran a separate cable, maybe. i don't know how campgrounds are wired.
if the voltage inside ur camper is under 110V, there probably isn't much u can do. u can try adapting to 50 amp service and see. just use a commercially available adapter. if ur reading abt 115 or so, i would suspect u have a weak breaker. the interesting thing is that it is usually the campground breakers that take the beating and become weak.
08-22-2011, 10:43 AM
HUMMM lets see, AC=20 amps
Microwave=10 amps
Converter= 5-15 amps
Water Heater= 15 amps
Where is the problem?
Too much amperage draw not enough available amps.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 569 |
| 93 members and 476 guests |
| 3 Husker Drips, 4-2-6, 4bnabird, AgentSmith, Al Fresco, Barney1, bikendan, Bill_C, bouldercamper, bradyashton, Cafjackracing, Canuck_Doug, caper, cbj, chadvc, cpope84, cyclepuck, dashonthedash, dasimser, david-o, daw592, dawg82, ddemme, DGrissom, Dodge Guy, DonG, donn, dware1962, Elidh, etbt1216, f1100turbo, Fire Instructor, Fitchy, FLBBQMAN, FreedomTracker, frfan, GASPEDDLER, Go Camping, Hilgy, Iggy, imabmwnut, Indy Steve, JamesR, jd-ford-hd, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jrat, jsutherl, KKapa, kvn4th, kz08h5, lami, LeonFournier, lowbubba, low_flyer, lurch, MAT8970, MikeFletcher24, Mpjduff, Msaunders, mtofell, N3HCP, nailit, Namchief, newtsx3, nightcrawler, nrcamp, pappcam, pbrackney, pchrcane65, polkatronron, PrairieBoy, racerx, RalphieG, Rebel702, RichardE, Rsgtivr6, seatosea, snjparham, softwarejoe, stevengb, Swinks, tabkld93, Terier, Triguy, troyt, unhcharger25, wingriders, wvfireboss |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
