Old 06-14-2014, 08:23 AM   #1
Needs Help
What do you use for leveling your Solera?
I know I can use 2x boards. Looking at leveling blocks, tri-levelers and anderson camper levelers.
What do you use? Do you worry more about side to side, or try and get the entire vehicle level?
2014 Forest River Solera 24S
Living_The_Dream is offline   Reply With Quote
Old 06-14-2014, 08:42 AM   #2
Loefflerh's Avatar
I used t be very picky ....not any more. I just use my calibrated eyballs and make sure that if the coach is not level the rear is higher then the front because of the bed arrangement. If I really get a very uneven campsite I carry 6 short pieces of 2x6 -and I make sure the wheels are fully supported across the full width and if I have to use something on the rear I support both wheels.
Loefflerh is offline   Reply With Quote
Old 06-14-2014, 08:51 AM   #3
I got my MH completely level using a four foot level, then I installed small stick on levels, one in front of the steering wheel and one below the driver side window. Using these it is often possible to move the coach a little bit around the parking spot to get the most level spot possible. They are real important in the worst spots, moving a few feet can get you very close to level.
Enconcapt is offline   Reply With Quote
Old 06-14-2014, 09:03 AM   #4
I made up some 2X10 and 1X10 boards to handle side to side leveling. For front to back I use the tongue jack on a block I made out of a 2X10 and 2X6's. It sets the jack base at about 8" off the ground. To date the most I have had to raise the TT is 3" side to side and have been well within the range of the tongue jack. This is in my driveway. The camping sites we have had were all pretty level or only needed a 1" board.
keith_h is offline   Reply With Quote
Old 06-14-2014, 09:06 AM   #5
MountainTrippers's Avatar
Leveling
I use 4 of the tri-level units and carry 4 2x8 boards. The tri-level levelers stack really well for storage. I use a 2' level on the floor and store it behind the drivers seat. I find that at the most I need to level 3 wheels. I use the rear levelers that came with the Solera to finish it off.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 06-14-2014, 09:27 AM   #6
2012 Solera 24S
I use the lego blocks and this bubble level app:
https://itunes.apple.com/us/app/bubb...ign-mpt=uo%3D4
Just lay it on the floor to my right from the drivers seat.
Nats is offline   Reply With Quote
Old 06-14-2014, 10:35 PM   #7
Sandiegodoug's Avatar
I also use 2 sets of Lego blocks and my I phone app
They stack quite nicely in the rear corner of my solera s compartment above the extra 2 1/2 gallon of def fluid
I carry.
Sandiegodoug is online now   Reply With Quote
Old 06-16-2014, 06:26 PM   #8
2015 Solera 24R
Sandiegodoug: Thanks for the phone app idea. I downloaded "Bubble". Looks like this bubble leveling app will work nicely. - Gary
Gary and Becky
Borrowing from Janis Joplin's "Me and Bobby McGee": Freedom is just another word for... RVing in a Solera.
RVing555 is offline   Reply With Quote
Old 06-17-2014, 12:42 PM   #9
2 sets of Lego blocks have done the job when needed.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 07-14-2014, 01:37 PM   #10
We have a bubble level in the refrigerator and carry 2x6 boards to drive up on in very un-level sites, but honestly, our Solera is almost always level if we try to find a decently flat site. We use our Bigfoot stabilizers as well and they can help level up if we're only a tiny bit off. Leveling the Solera is a dream compared to our previous much longer coach. If we need to use the blocks, we only need to drive up them usually to raise the front a few inches.
The Nutter Family
2015 Solera 24R
knutter is offline   Reply With Quote
leveling, solera
