Old 05-24-2015, 08:38 AM   #1
CharSolera's Avatar
What's this?
I found this antenna in the passenger seat cubby. Radio, Sirius work fine. Is this just extra? It has the MB logo on it. 2014 Solera 24S.
ID:	77881   Click image for larger version
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 05-24-2015, 09:21 AM   #2
hkreck's Avatar
I wonder if it's the antenna from the MB chassis that was taken off when they build the coach and someone thought you might want it?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 05-24-2015, 11:03 AM   #3
Mikegjax's Avatar
That is what it is. They forgot to remove it.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-24-2015, 12:23 PM   #4
FLPhotographer's Avatar
I had one also in the glovebox when I picked up my Solera 2401R.
In the end, it's not the years in your life that count. It's the life in your years. - Abraham Lincoln
FLPhotographer is offline   Reply With Quote
Old 05-27-2015, 09:27 PM   #5
GM
bclemens's Avatar
Not sure why they keep shipping them....other than we have no use.
That is on the cab portion that gets cut out. We install our own antenna on the roof.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-28-2015, 08:25 AM   #6
I wish they'd route the Sirius XM antenna to the roof. Mine appears to be on the dash by the windshield. I hope that doesn't cause reception problems.
ericlakin is offline   Reply With Quote
Old 05-28-2015, 08:27 AM   #7
GM
bclemens's Avatar
We do. The antenna you see on the dash is the GPS antenna. The XM module is routed to the roof.
Old 05-28-2015, 10:05 AM   #8
That's good because I can't live without XM on long trips!
Old 05-29-2015, 10:10 AM   #9
'79 Bonneville
The Sirius satellites are normally fairly low in the southern sky so if you are passing by a mountain on the north side, you might lose the signal until your antenna gets a clear view of that portion of the sky again. Dense foliage can sometimes have the same effect.
If you have an older self-installed magnetized antenna and you put it on the steel hood, you are likely to lose the signal when driving north because the signal will be blocked by the tall coach body. Kudos to FR for making the roof mounted antenna and the tuner standard equipment.
bcunning is offline   Reply With Quote
Old 07-13-2015, 04:18 PM   #10
XM Antenna?
So, is there a factory installed XM antenna on the roof of my 2013 Solera 24R?
TIA,
Greg
gfior is offline   Reply With Quote
