Old 09-25-2015, 03:17 PM   #1
Wheel Chock/Leveler
I have a 2010 FR Solera 24S with dual wheels on the back. Thinking about getting Anderson Camper Wheel Chock and Leveler. Do I need one for each of the four back wheels or can you just use two? New to having dual wheels.
alaska6580
alaska6580 is offline   Reply With Quote
Old 09-25-2015, 03:45 PM   #2
Fred H.'s Avatar
With dual wheels always remember, never use any lifting device on one tire. Ramps, etc. must be placed on both dual wheels.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 09-25-2015, 03:56 PM   #3
Just to make sure I understand correctly. I have single axle with two wheels on each side so I will need four wheel chocks/levelers
Old 09-25-2015, 04:29 PM   #4
Ford Idaho's Avatar
Unless you can find two that are real wide you WILL NEED FOUR.
Old 09-26-2015, 06:40 PM   #5
yes, always use 4, or the entire weight will be supported by only two tires, likely damaging the sidewalls and increasing the risk of a blowout.
we've had good results using Lynx Levelers ( the orange blocks ).
jdyson
(former owner, went back to Class A)
(but enjoyed our brief 'experiment' in downsizing!)
'16 Forester MBS 2401R
Hellwig 7254, TireMinder A1A & Sumo Equipped
jdyson is offline   Reply With Quote
Old 09-26-2015, 08:00 PM   #6
hkreck's Avatar
X3 on the this information, although when I was on the fire dept. we would put the rear duels up on ramps to chain them up in the Winter for snow. We would put the ramp under the inside duels and chain up the outside tires. IN some cases we would have the trucks up like this for several days and it didn't do any harm. Don't know if there is a difference between the two types of vehicles?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-27-2015, 09:03 PM   #7
I use 3. The situations I have found are low in the front (use 2) and low on a side (use 3). Of course you could have a low in the back calling for for 4.
SSmbs is offline   Reply With Quote
wheel
