Old 12-04-2015, 11:53 PM   #1
Which shocks for the rear 2015 24R?
Installed the Hellwig stabilizer bar on the 2015 24R from advice from this forum. Made a BIG difference. Reduced the "butt clenching truck suck" sway from the 18 wheelers blowing by me at 80 mph. Should be a standard upgrade on Sprinters! Decided I want to improve even more by either adding sumo springs or the Bilstien shocks. Doing internet research there seems to be confusion which shocks go on the back. Anybody installed any and which model number is it? Do the Sumo shocks transfer more road noise from riding on the axle to frame? Are they a harsher ride?
Tommy G is offline   Reply With Quote
Old 12-05-2015, 12:12 PM   #2
I have a 16 R and it came with Hellwig but am really interested in the shock answer and Summonsorings as well.
Dogpa
dogpa is offline   Reply With Quote
Old 12-05-2015, 09:30 PM   #3
I just installed the bigger sumo springs on my 24r. These are the ones that connect to both the frame and the axle. I haven't had a chance to drive it yet, but the tech called to say the rear sits a little higher. I'm done with the sway. Installed helwig as well. $750 well spent if it does what I think it'll do. Unfortunately I won't be driving the rig till mid January when we head for Florida and the southern Gulf coast.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 12-06-2015, 05:46 PM   #4
BD, did you install only on the rear? Let us know what you think when you take it out. Thanks
Old 12-06-2015, 08:27 PM   #5
Yes. When I spoke to the Suspension Connection folks, they suggested the heavier duty *ssr-336-5 sumo spring for 2010-2015 Mercedes Sprinter*in the rear only. Along with the helwig sway bar, he felt that would resolve the majority of the issue. If things persisted, I could add the front units, but he was pretty confident that wouldn't be necessary. They even refunded the coupon savings that if forgot to include with the order. Great folks and super service.
Eric Jackson
2015 Solera 24R
Old 12-07-2015, 09:55 AM   #6
RedLdr1's Avatar
I'm still on the fence about Sumo's so I'm also looking forward to your update on how well these work. Our "W" had the Hellwig sway bar factory installed and the sway on the highway isn't too bad. From everything I've read here and on other forums adding Sumo's really improves the ride and handling of a MBS.
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 12-07-2015, 12:46 PM   #7
Cfritts's Avatar
Now that we are having this conversation (again) when I called they wanted to know if my 2401W had a "block on the axle". I of course have no clue. They said it depended on which one they sent me. Sumo Springs. And the numbers I was given are not SSR 336 5 but rather SSR 336 47 1 (without block on axle), no number 1 at the end if it does have the block on the axle.
I feel like different numbers have been given. I have the MBS 3500 2015 model under a 2016 motorhome build, I have verified my sprinter is a 2015.
I finally found someone who can install them but I need to buy them and have not yet due to which item # for sure they are!
Cfritts is offline   Reply With Quote
Old 12-07-2015, 12:52 PM   #8
Pod2Vibe's Avatar
I think that adding Sumo's all the way around was the best mod ever.
Not only do they greatly help the sway and rocking, they make for a much quieter and smooth ride.
They also made the rig more naturally level. The last few campsites I have pulled into, I have not had to do any kind of leveling.
In addition, the rig is so stable once parked at campsites, I don't use the Bigfoots anymore.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 12-07-2015, 05:05 PM   #9
What company are you all ordering the Summos from. I have a 2016 Solera R. How did you figure out what year the chassis is?
Dogpa
Old 12-07-2015, 06:16 PM   #10
P2V Did you do any other suspension mod? Sway bar or shocks? Good to hear they are quite and smooth. Did you install yourself? If so, how difficult?
