Old 01-30-2014, 10:02 PM   #1
Who makes the supplied battery,s
Recently purchased my second Solera in October . Battery's can not hold a charge . I was told by dealer to contact battery manufacturer. Nothing on either battery identifies the manufacture. Looked on all four sides. Any help would be appreciated. Perhaps B.C. Is reading this posting
Dish is offline   Reply With Quote
Old 01-30-2014, 10:11 PM   #2
Phat Phrog Stunt Crew
awwall's Avatar
If it is a new RV, then they should be covered under warranty?
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 01-31-2014, 12:20 AM   #3
Yes by the battery company
Old 01-31-2014, 08:33 AM   #4
Try this; do a search on any specific information you can get off of markings on the battery. Type it in all different ways. Their are only a couple mfgs. In the US. The manufacturer's code number on the battery will also identify the manufacturer. That will help you reverse look up back to the manufacturer. Then if successful, look into their distribution chain to find a distributor. My guess is they will pro-rate them based on months in service. Good luck.
2012WhiteSolera is offline   Reply With Quote
Old 01-31-2014, 09:10 AM   #5
TURBS's Avatar
Did the dealer not tell you the manufacturer of the battery?
Your dealer is pretty crappy imo.
If your dealer installed the batteries then the are the servicing shop for the batteries they install.
In 2005 I bought a 2005 flagstaff and had dual batteries installed.
They lasted 6 mo. For whatever reason.
I took them back to the dealer for free replacement no questions asked.
Now if your batteries were installed at the factory then your "great" dealer should be on the phone the second you claimed foul on the batteries trying to help you hand over foot.
They must not value you as a customer that they brush you off to speak to the manufacturer of said batteries.
Shame on them that you spent that kind of money to brush you off.
TURBS
oc's buddy
Old 01-31-2014, 03:39 PM   #6
boats742's Avatar
My 2 coach batteries were DOA - and defective when I bought my new 2013 Solera. I knew I wanted to upgrade to AGM's so I purchased 2 AGM batteries from Sears. I know for owning many boats, the AGM is best suited for this type of application (low self discharge, faster recovery, not damaged by repeated discharges and truly maintenance free.
2013 Solera 24S
Charleston, SC
boats742 is offline   Reply With Quote
Old 02-02-2014, 04:24 PM   #7
Hey boats742,
Need more info please: Do you have a part number, etc.- approximate cost per battery thru Sears-Thanks.
Respectfully,
CaptDan
CaptDan is offline   Reply With Quote
Old 02-02-2014, 04:52 PM   #8
mark0224's Avatar
I agree Dealer should take care of. Tell dealer that battery won't hold charge when unit is plugged in and get them to look at charging system and while your there put the service manager on the line, if he won't do something go higher there. If I bought an new car and the battery died I'm not going to pay for a new battery and neither should you for the rv.
mark0224 is offline   Reply With Quote
Old 02-05-2014, 07:54 AM   #9
boats742's Avatar
Originally Posted by CaptDan View Post
Hey boats742,
Respectfully,
CaptDan
I use the Sears Platinum Marine AGM batteries size 34M. They cost about $230 each, but worth it IMHO.
2013 Solera 24S
Charleston, SC
Old 02-07-2014, 10:04 PM   #10
GM
bclemens's Avatar
Those are Exide batteries.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
battery
