Old 09-16-2012, 11:56 PM   #1
Wiring diagram / fuse location for ext. rear light
Brought my new 2013 Solera 24S home this weekend and my rear side light doesn't work. It did work during the Inspection and I tried to look thru the piles of manuals but couldn't find a schematic
Antiochrich is offline   Reply With Quote
Old 09-17-2012, 05:54 AM   #2
Coachmen Adrenaline
rear slide light? can you be a little more specific where this light is? inside the slide...the rear light in there?
jamiller45 is offline   Reply With Quote
Old 09-17-2012, 06:15 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Your fuses should all be in the converter where ever it is located and it is propabaly a WFCO brand. Just push on the top center of the panel on the front and it will pop open far enough for you to pull it down and you will see all your fuses and cct breakers in there.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-17-2012, 06:18 AM   #4
Wanna Be Camper
Outside light not slide light.
John & Deb
Old 09-17-2012, 06:22 AM   #5
TURBS's Avatar
Checked the bulb right ?
Old 09-17-2012, 07:20 AM   #6
Wanna Be Camper
Doh,
Now why didn't I think of that Ron????
Here is a link to WFCO and there is a pic of a distribution panel open and on the top one of it closed so you know what to look for.
Distribution PanelsWF-8930/50, WF-8930/50 50 Amp Distribution Panel
John & Deb
Old 09-17-2012, 07:40 AM   #7
TURBS's Avatar
Originally Posted by TheSasks
Doh,
Lol sometimes the simplest things !
I had my porch light go out on the very first day I had my 5er.
After checking fuses and making sure there was power at the switch dw said "check the bulb"
I said it's brand new !
One bulb later we were back in bidness.
Turbs
Old 09-17-2012, 09:14 AM   #8
Thanks for the quick replies, it is the light on the drivers side exterior above the sewer outlet connection on my Solera and no, I didn't check the bulb...yet.
Just thought there were more fuses/panels that I didn't know about.
2013 Solera
Old 09-17-2012, 10:57 AM   #9
Coachmen Adrenaline
Sorry, I must've misread the first time. The outside "scare" light should be on circuit 3 of the 12V side in your distribution panel.
Old 09-17-2012, 11:36 PM   #10
Well, before I got a chance to check the bulb the light worked so....If it aint broke, don't fix it?
2013 Solera
