Old 11-26-2014, 10:37 AM   #1
Woes of Winterizing 24R
In the process of winterizing the 24R, opened the rear compartment, to a well labeled valve, switched it, opened the access door which fell off in my hand, due to poor installation technique. It had a strip of double sided tape which neither stuck to the door or the hinge.
Opened the tank drain. All well. Dropped the dip tube in a jug of PINK, nice, just like my old 99 Lance slide in.
Went inside and bypassed the water heater which was behind a wooden panel with 6 screws, went ok, could have had a regular door but I understand that would add to the cost.
The water filter cartridge was not installed, so ran all faucets until pink. Great.
Except the filter housing only had about 3" of PINK.
Pulled the filter canister from the housing, which was wedged between the door and the carpet behind it.
Now the big question. How are you supposed to get the filter back on the housing
The room is 1/4" smaller than the canister.
Have you been cutting out the carpet? Carving up the doorframe?
I hope this is not a sign of things to come. It's falling apart faster than I can fix it, and I've only had it a week.
Flydrifter is offline   Reply With Quote
Old 11-26-2014, 12:38 PM   #2
Hmm. Not sure. In my case (2015 24R) the fit is very tight, but I can get it in. It's a bit more difficult with the cartridge in the cannister, because you've got to get the cartridge lined up correctly...but it does fit.
Dave
DaveJordan is offline   Reply With Quote
Old 11-27-2014, 11:36 AM   #3
Found another thread that indicated cutting a square of carpet out made it workable.
I'm not sure the guys that designed this thing ever really used one.
Old 12-05-2014, 11:14 AM   #4
GM
bclemens's Avatar
I have covered this before. We have and we do. Trying to cram a lot of stuff into small spaces...sometimes the line does not always put them exactly where we ask.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-12-2015, 03:21 PM   #5
Hmmm - maybe slightly different with my 2015 24R. Not sure what you did on “opened tank drain” - was that the hot water tank? My steps were:
1. Drained black/grey tanks
2. Removed the water filter cartridge and dumped its contents. I did have to trim the styrofoam insulation in order to take the cartridge holder off.
3. Removed the 6 screws on inside panel to switch/bypass the 3 hot water valves.
4. Removed the drain plug on hot water heater.
5. Filled water tank with about 4 gals of antifreeze.
6. Pumped all faucets/toilet until pink.
7. Poured about 2 gals of antifreeze in drains (2 sinks/shower)
8. Poured a gallon of antifreeze through the toilet.
9. Could not determine when water line to pump manual switch should be set on winterize or normal. So I did all the above on normal and then switched it to winterize.
All in all this seemed easy.
Dave
DCBnDLB is offline   Reply With Quote
Old 01-12-2015, 08:13 PM   #6
Mikegjax's Avatar
You put antifreeze in the fresh water tank? Should use the winterizing valve and pump to draw antifreeze into the system. Only need to drain the fresh water tank and no antifreeze.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-13-2015, 10:28 AM   #7
That makes sense but that is not what I'm reading in the FR Manual for Water System Winterization. After draining tanks, WH bypass valves, drain WH and removing filter, it states:
"5. Fill the tank above minimum water pump operation level with the RV antifreeze. (Use of a long funnel may be helpful.)"
Next step is turning pump on and opening cold side of water faucets until they flow pink.
To me that's putting antifreeze in the fresh water tank. Am I missing something??
As I mentioned earlier there is a valve behind the water pump panel (accessed via outside door) that has 2 positions; NORMAL and WINTERIZE. Maybe that is what you are referring to on pumping straight from antifreeze bottle? However there is absolutely no mention of this valve in manual! So I was only guessing that this valve prevents fresh water from going into the water tank.
Old 01-13-2015, 04:01 PM   #8
Mikegjax's Avatar
The Normal/Winterize valve allows you to winterize without putting antifreeze in the fresh water tank. It is not a big deal that you did. It just makes it more of a pain to flush the tank several times to completely purge the tank of antifreeze.
Next time you winterize just stick the hose connected to the valve into the antifreeze jug, select winterize on the valve and then turn the water pump on. Makes things a little easier.
There are other threads on the Solera forum that discuss winterizing.
BTW, the manual is pretty generic and not all RV's have the winterize valve.
Enjoy your rig! I love mine.
2014 Solera 24R
USN Retired
Old 01-13-2015, 05:24 PM   #9
Flybob's Avatar
Originally Posted by DCBnDLB View Post
H
You are just trying to fill the "U traps" in the drains which should only require 1-2 cups of antifreeze. Any more than that simply runs into the black or grey water tanks.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-13-2015, 05:53 PM   #10
Thanks for all the advice. It seems like this year was an overkill! Live and learn!
Regrettably the manual is not really a manual - but general guidance material.
winter, winterize
