Old 05-18-2014, 01:29 PM   #1
XM Antenna installation
I'm installing the XM antenna in our Lera and looking for advice on how some of you guys routed the antenna wire. I plan on placing the antenna itself in or close to the celling fan up front. Of course I want it to look good and not be able to see the wire running down the side of the wall.
Any help would be appreciated, thanks.
2013 Solera S
CHILL is offline   Reply With Quote
Old 05-18-2014, 02:18 PM   #2
Why not on the dash?
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-18-2014, 04:22 PM   #3
Mikegjax's Avatar
On my 24R I ran it behind the dash to the passenger side door and then tucked it behind the rubber trim around the door frame and rear pillar. Loosed one screw to work it behind trim around the upper mattress cutout area. Then ran it under the mattress to the front of the cap. I lose the signal sometimes when headed north. I think that is mostly because of all the stuff piled up there. The cable can't be seen.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-19-2014, 06:34 AM   #4
With a class C you will get poor reception due to the overhanging bunks above.
2013 Solera S
Old 05-19-2014, 06:41 AM   #5
I see what you are saying now. Thanks.
Old 05-19-2014, 08:08 PM   #6
I ran it to the fan and zip tied it to a cross brace above the fan from the roof. Looks good and works Great!
Sent from my GT-P5210 using Forest River Forums mobile app
Goat_7 is offline   Reply With Quote
Old 05-19-2014, 09:31 PM   #7
I had a professional install it on a class c and he ran it under the passenger door step molding behind the dining table along the floor and to the side door molding which he removed and ran it up under the molding and then somehow in the wall and out the top where the awning attaches and then used some kind of black caulking to adhere it to the top. Works great but he said it was a *****
Pacostaco is offline   Reply With Quote
antenna
