Old 07-21-2017, 09:50 PM   #1
A/C vents
So I just did my first mod to the front and rear a/c duct.
Does anybody know were to get the vents that are one directional and close. The only ones I've seen are smaller than what's in here.
These are what I want to replace
(Pic is side ways...that is the roof vent)
TEXAS-BOB is offline   Reply With Quote
Old 07-21-2017, 10:03 PM   #2
Fulltime family RVer
Here's what I used in my bathroom ceiling:
JR Products ACG25DPW-A Polar White Adjustable Ceiling Vent with 0.25" Collar
https://www.amazon.com/dp/B0095TEFNA..._gbSCzbBN5HQG7
Old 07-21-2017, 10:16 PM   #3
Did you have the same vent I posted? Mine is 7" and the inside is 5". Wondering if it will be close enough to fit.
Old 07-22-2017, 01:42 AM   #4
Here are my measurements. I did not have the same original vent as you.
I can't pull it down right now but the inside opening is slightly larger than what I measure as this is the inside of that.
Old 07-22-2017, 01:43 AM   #5
Ac vents
There is a ring that you mount first and then the vent clips into it. My bet is this one would work if your inner circle is 5".
Old 07-22-2017, 07:49 AM   #6
Attachment 145647
Attachment 145648
Thank you very much for taking these pics. Seeing the tape measure up there helps. I'm thinking these will work,going to order one now to try out. Thanks again
Old 07-22-2017, 08:16 AM   #7
mblee21's Avatar
Let us know if it works. I have the same vent as you and want to replace them.
mblee21 is offline   Reply With Quote
Old 07-22-2017, 08:23 AM   #8
yessir will do!
Old 07-25-2017, 09:20 PM   #9
Update......So the Vents Didn't Fit,They Were To small. I also tried another but it was also to small.
On the one in the link above, the mounting holes are at the edge of the hole in the roof. I'm thinking I might be able to still make it work by using the original mounting ring as the base for the new vent or by making tabs to screw into..., I'll update with what I come up with, as I've still not found any others.
Old 07-26-2017, 10:31 AM   #10
Head Rambler
There are a few of us that have changed our large a/c registers.
Here is the thread where I made some mods and the vent part numbers are in post #11. Bamas Rambling Mods
Gotta go campin!
vent
