07-21-2017, 09:50 PM
A/C vents
So I just did my first mod to the front and rear a/c duct.
Does anybody know were to get the vents that are one directional and close. The only ones I've seen are smaller than what's in here.
These are what I want to replace
(Pic is side ways...that is the roof vent)
07-21-2017, 10:03 PM
Always Learning
Here's what I used in my bathroom ceiling:
JR Products ACG25DPW-A Polar White Adjustable Ceiling Vent with 0.25" Collar
https://www.amazon.com/dp/B0095TEFNA..._gbSCzbBN5HQG7
07-21-2017, 10:16 PM
Originally Posted by ependydad
Did you have the same vent I posted? Mine is 7" and the inside is 5". Wondering if it will be close enough to fit.
07-22-2017, 01:42 AM
Always Learning
Here are my measurements. I did not have the same original vent as you.
I can't pull it down right now but the inside opening is slightly larger than what I measure as this is the inside of that.
07-22-2017, 01:43 AM
Always Learning
Ac vents
There is a ring that you mount first and then the vent clips into it. My bet is this one would work if your inner circle is 5".
07-22-2017, 07:49 AM
Attachment 145647
Attachment 145648
Thank you very much for taking these pics. Seeing the tape measure up there helps. I'm thinking these will work,going to order one now to try out. Thanks again
07-22-2017, 08:16 AM
Let us know if it works. I have the same vent as you and want to replace them.
07-22-2017, 08:23 AM
yessir will do!
07-25-2017, 09:20 PM
Update......So the Vents Didn't Fit,They Were To small. I also tried another but it was also to small.
On the one in the link above, the mounting holes are at the edge of the hole in the roof. I'm thinking I might be able to still make it work by using the original mounting ring as the base for the new vent or by making tabs to screw into..., I'll update with what I come up with, as I've still not found any others.
07-26-2017, 10:31 AM
There are a few of us that have changed our large a/c registers.
Here is the thread where I made some mods and the vent part numbers are in post #11. Bamas Rambling Mods
Gotta go campin!
07-26-2017, 11:26 AM
Bama I sure do preciate it, just placed an order for 4!
07-29-2017, 11:04 PM
Bama I just installed 4 and they popped right in,I sure do a preciate you chiming in,thanks!
07-30-2017, 08:29 PM
Glad they worked for you, and that I was able to give a little assistance.
Gotta go campin!
07-31-2017, 10:17 AM
Just curious, how did you remove the old vent? I can't seem to get mine out.
07-31-2017, 10:58 AM
There is 2 pieces, a ring that's screwed to the ceiling and then the actual vent. The vent will just pop off the ring.
08-01-2017, 01:07 PM
As Bob said, they just pop out of the mounting ring. Get a fingernail (or small flat screwdriver) under the lip of the vent and pry down.
Gotta go campin!
02-19-2018, 10:16 PM
DW Jetstream's website sells a few different options from color, collar height, and diameter. Anyone done it for a new vibe 313? If not I'm gonna pop it out in morning.
02-23-2018, 01:29 PM
02-26-2018, 08:46 PM
Originally Posted by RolltideRoo
I have the same Vibe, please provide what size vents you bought them at on what website, I need to so the same
02-27-2018, 05:34 AM
The price was for four. Manufacturer and model is noted on pic, got them on eBay.
