Old 02-21-2016, 09:22 AM   #1
fireman1317's Avatar
Anyone know the distance?
Does anyone know the distance from the outside of one tire to the outside of the tire of the next axle? Preparing boards to set our 315BHK on at the asphalt storage lot when we get it at the end of the week. Thanks
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 02-21-2016, 09:35 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Prepare???? Get two 4'X8' boards, don't cut the ends at an angle thinking the tires will roll up easier. You'll just make a set of chocks if you do, and the trailer will shove them across the asphalt.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-21-2016, 09:40 AM   #3
One must "prepare" when today is the only day I don't have a child in tow and the weather is nice. Got to get things done when I can!
I really hope you don't mean 4ft by 8ft. I was thinking of a 2"x12" or 2"x10" board under each side. Just trying to find out how long a board I would need to make sure both tires are up off the asphalt. Thanks
Old 02-21-2016, 01:09 PM   #4
I think he meant 8" by 4'. Leaving the ends square is something I never thought of but makes sense.
Flower is offline   Reply With Quote
Old 02-22-2016, 08:15 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Yes I did. Sorry.
Fireman, get more length than is minimum in case one board slips a little.
Wright and Penny
Richmond, Va.
Old 02-22-2016, 08:29 AM   #6
jeff64's Avatar
You can figure the span between the axles is less than 8 ft.(max trailer width). I used a pair of 2x12x4ft under each axle set. Gives you a little more wiggle room from side to side. They're heavy enough square cut that they don't move when you drove on to them and the weight is distributed over a greater area than single boards. 2x10s would have worked too. I screwed a piece of 4x4 to one side as a rear stop and used treated lumber for longevity
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 02-22-2016, 08:43 AM   #7
SeaDog's Avatar
As has been said 48" span will ensure both tires are on the board. I have never been concerned with getting the tires up off asphalt or my concert shop floor. My car hauler that sits outside the tires in contact with the ground and the moisture from it so I put that trailer up on 2x10x48"
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-22-2016, 11:33 AM   #8
OK, I'll ask... why do you want it to sit on wood, instead of asphalt?
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 02-22-2016, 11:53 AM   #9
Canadian Member
itat's Avatar
He wants something to elevate one side for leveling left-to-right.
I use PT boards as well. I have one long one (about 5') and a shorter one (about 4'). That way if I need the extra height to level I can stack them and the longer one on the bottom acts as a ramp up to the shorter one on top. I'd like to find a 1x8 or 1x10 to allow for a finer adjustment.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-22-2016, 11:55 AM   #10
Mainly because the asphalt is fresh and I don't want the tires sitting on it when it gets hot. That and it just seems like it would be better on the tires.
