08-24-2012, 05:06 PM
Black tank backwash
I saw this in the brochure and wondered if anyone knows what this is and how to use it. thanks
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
08-24-2012, 05:09 PM
You must have forgot to post the link to the brochure. Can't see it anyway.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
08-24-2012, 05:21 PM
2004 Dodge Dakota
08-24-2012, 05:22 PM
sorry it says black tank flush
2004 Dodge Dakota
08-24-2012, 06:11 PM
The black tank flush is for cleaning out the black tank. At the dump station they somtimes have a hose that you hook up to the flush. There is a sprayer in the tank that washes the inside of the tank.
I have the vibe 6501 and have used it a few times.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
08-24-2012, 06:21 PM
where do you hook it up?
2004 Dodge Dakota
08-24-2012, 06:27 PM
Did you get the Value Pack that includes it?
It usually is located close to the water inlet or near the dump valves.
It should be clearly marked if you have it.
08-24-2012, 06:28 PM
i'm supposed to have the value pack. what is it labeled?
2004 Dodge Dakota
08-24-2012, 07:14 PM
It is labeled black tank flush. If you look on line you will see pictures that some dealers have taken that will show it. The only option on the 6500 series is the TV. The other options are mandatory, not sure how that makes them an option.
Ontario
08-24-2012, 07:33 PM
where do you see them? i have looked all over the website.
2004 Dodge Dakota
08-24-2012, 07:36 PM
i found it, right beside the outside shower. thanks a lot
2004 Dodge Dakota
08-24-2012, 08:15 PM
Director, FROG
ALWAYS be sure that the black tank valve is open when using the flush. Otherwise, the only place for the filling tank to go us up the toilet and then to places where you don't want black water.
08-24-2012, 08:16 PM
great thanks
2004 Dodge Dakota
08-24-2012, 08:33 PM
I don't allways have the black tank valve open. I will fill the tank about a quarter full after the first dump so i have enough flow to flush out the nasty stuff. The black tank has a vent going to the roof so the air ( and smell) displaced by the water will go out there. You do not want to leave while you are filling the tank because if you over fill the tank you will damage the tank and have a nasty mess to clean up.
Ontario
08-24-2012, 08:37 PM
The lawyers, of course, require a sticker prohibiting that; just in case.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-24-2012, 08:44 PM
Yes i have seen that, The lawyers have to save us from our selves. Same as the statment in my WD manual that says not to drive with the rear wheels removed from the tv.
Ontario
08-25-2012, 06:09 AM
The sticker if for the very same reason.
08-28-2012, 07:56 AM
Always Learning
Interesting enough - my Sabre has a black tank flush from the factory, but no sticker. It's actually how I happened upon this thread!
