Old 05-04-2015, 02:34 PM   #1
Black tank flushing system
Was flushing black tank. Had a back flow preventer in line. Notice water coming from under trailer. Never had this problem before while flushing tank. Check for a leak. Looks like there is a right angle black square thing in line with water flow. Has these markings B&B, model number 571. Also 110f or a p and 125 psi. Is this a combination check valve back flow preventer? The water seam to be coming from it. Thanks for your help
dgkbear is offline   Reply With Quote
Old 05-04-2015, 02:47 PM   #2
Mine would leak occasionally so I finally just took it out along with about 10' of hose and connect the hose directly to the inlet behind the back flow valve. Works just fine.
Old 05-04-2015, 02:56 PM   #3
Witch Doctor's Avatar
Where is the back flow valve located. must be after the vacuum break, maybe before the head, I do not have one that I can see? surely not going to drop the bottom and look. Where did you find yours or did you just add one?
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-04-2015, 03:01 PM   #4
Behind the outside hose connection inside the camper. It is connected to the hose connection. Just cut the hose off and find the hose that goes down into the underbelly, cut the hose and connect it to the back flow valve. Real easy, takes about 5 minutes.
Old 05-04-2015, 04:18 PM   #5
I understand where I can add one, my problem is the black flush is between the shower surround and the outside wall. I can't even reach it. From that back valve it go's down under the unit between the floor and the enclosed bottom. If it breaks I'll just have to figure out how to run a line directly to the head and just leave what is there now. Lets hope it don't break. I can not believe they did not make it accessible. Thanks.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-04-2015, 06:09 PM   #6
Not talking about the valve behind your shower surround, the back flow preventer I'm talking about is on the back side of the hose connection you use to flush the black tank. The hose originally comes in from the outside and goes up to the vent/backflow valve (was under my bathroom lavatory and behind your shower surround) and then down into the black tank. All you have to do is remove the hose from the inside of the hose connection and cut the hose going into the black tank and connect it to the inlet hose.
Top picture is the back flow preventer (brass fitting with arrow on it) on the back of the outside hose connection.
Bottom picture is the outside hose connection
ID:	76146   Click image for larger version
Old 05-04-2015, 08:32 PM   #7
Well you just put a check valve in line. I'm not worried about that my concern if my Black Valve vacuum breaks. I have no way of repairing it. You can't get to it even to put a brass one in. a check valve will not stop the Vacuum valve from breaking in my wall.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-04-2015, 08:38 PM   #8
I never put anything in, it is factory, all I did was remove the valve and hoses you're worried about.
Old 05-05-2015, 05:10 AM   #9
It's like I said months ago. Flagstaff units cost a little more then Rockwood, and thank you for proving my point. They do come with little extras that Rockwood's do not...
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-05-2015, 07:41 AM   #10
Your Rockwood has the same valve if you look. They have to have it to keep possible back flow from the tank.
black, black tank, black tank flush, tank
