Old 06-18-2011, 05:16 PM   #1
RichnVinny's Avatar
Black tank light
I fully drained and flushed black tank and light still says 3/4 full what can I do to get light to show tank empty
We love our brand new 305V RET fifth wheel
RichnVinny is offline   Reply With Quote
Old 06-18-2011, 05:26 PM   #2
backin15's Avatar
You probably have some debris across the sensors giving a false reading. You need to clean the tank. You can use a cleaning wand which you insert into the toilet opening, a Flush King which allows you to backflush the tank from the discharge opening, or a Quickie Flush which is a device that permanently mounts to your tank.
backin15 is offline   Reply With Quote
Old 06-18-2011, 05:50 PM   #3
RichnVinny's Avatar
If I have a black flush connect can I use that?
Thanks for the help
Old 06-18-2011, 07:05 PM   #4
backin15's Avatar
Yes - that should be the same as a Quickie or Tornado flush. Connect a water hose to it and let it run for a few minutes. That should take care of it. I use a clear elbow on the sewer connection so I can see when the water is running clear. Please do not use the same hose you use for your water connection. If that does not get the indicator back to reading empty you can try filling the tank to about 3/4 full and dump a bunch of ice and drive around a while. The ice will rub any buildup off the sides of the tank. Good luck!
Old 06-18-2011, 07:25 PM   #5
sherdep's Avatar
backin15 posted some good info there.
you could also fill the tank with water and let stand for atleast a few hours to try and soften up what is stuck on the sensor and then drain the tank and then flush with the wand.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-18-2011, 10:49 PM   #6
Thanks for the help
We use the installed black tank flusher after EVERY dump, whenever there is a water source available. I just assumed that everyone did that .
...VTX-AL
VTX Al is offline   Reply With Quote
Old 06-19-2011, 06:34 AM   #7
RichnVinny's Avatar
I got it cleared I always use a seperate hose and have a clear ens on black hose too, just this last trip the sensor light still showed 3/4 full so I was like wtf?...anyway running the flush alittle longer worked, thanks for the help and tips
Old 06-19-2011, 06:36 AM   #8
RichnVinny's Avatar
vtx...we do too just this time maybe I didnt do it long enough...anyway problem solved thanks
Old 06-19-2011, 07:01 AM   #9
Herk7769's Avatar
Try a search on horst probes. I replaced the stock probes with them and they work great. No more "hangers" on the probes.
HAM CALLSIGN - KC3FFW
black tank
