Old 06-24-2018, 10:11 PM   #1
alain h's Avatar
Black water tank flush hookup
Tried to hook up our garden hose to our tank flush hook up but no water go in
It just above the city line hook up
Any idea ????
Brand new vibe
alain h is offline   Reply With Quote
Old 06-24-2018, 10:26 PM   #2
woodyrock1's Avatar
This might be a silly question but is your black tank empty?
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 06-24-2018, 10:42 PM   #3
alain h's Avatar
Yes
Old 06-24-2018, 10:44 PM   #4
alain h's Avatar
We dump our tank today and try to flush it since we were at a full hook up site
But nothing was going in
Old 06-24-2018, 11:00 PM   #5
woodyrock1's Avatar
So you used the water at the campground/campsite? How was the water pressure, maybe there wasn't enough pressure to get things working. Another maybe silly question. If you use a water pressure regulator attached to spigot, assuming you changed out you fresh water line for another hose dedicated for black tank is it possible you didn't detach water regulator causing low water pressure preventing black flush to function properly?
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
Old 06-24-2018, 11:33 PM   #6
woodyrock1's Avatar
Here's a thread on a very similar issue that you are having, hope it helps.
https://www.google.com/url?sa=t&rct=...0zPbuKdIz07JHJ
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
Old 06-25-2018, 05:32 PM   #7
Maybe you were hooked to pump antifreeze line and not black tank flush??
davejodoin is offline   Reply With Quote
Old 06-25-2018, 10:58 PM   #8
i had the same problem this is the what i found out.
http://www.forestriverforums.com/for...ng-142749.html
Vibe 308BHS - 2017 F250 6.7
Krazo is offline   Reply With Quote
Old 07-03-2018, 10:39 PM   #9
alain h's Avatar
Nop
Have a look
Old 07-28-2018, 04:24 PM   #10
RolltideRoo's Avatar
I have a 313 my black flush is below the city.
RolltideRoo is offline   Reply With Quote
Old 07-28-2018, 07:43 PM   #11
Check this
First time i hooked up the city water connection, i found the labels where backwards. I was connected to the label city wster connection and it was actually theblack tank flush. It filled the black tank and backed up in the bathroom. I changed the labels around and all is well.
virstens is offline   Reply With Quote
black, black water, flush, tank, water, water tank
