Old 03-27-2016, 07:27 PM   #11
Buy 30 amp or 50 amp?
This also depends were you camp. We camp at provincial parks and I have never been at a site that has 50A service.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-27-2016, 07:29 PM   #12
Kenny kustom's Avatar
Bang on.
I've never been to a CG with 50A service.
I have a 50A rig, w 2 ac. So Can't run both anyways.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-27-2016, 07:45 PM   #13
It looks like 50 amp is the way to go! Thank you so much for the responses. We were on the fence because there was a 30 amp in stock and it will take 4-6 weeks to have the 50 amp ready for pick up. I think it will be worth the wait though : )
Abrooks is offline   Reply With Quote
Old 03-27-2016, 07:53 PM   #14
caper's Avatar
Plus if you do some early or late season camping the 50 amp will allow you to use 2electric heaters in the unit while still being able to make your morning coffee.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-27-2016, 08:31 PM   #15
If you go to campgrounds that don't have 50amp service but you have a 50 amp until you can get a dog bone adapter that you plug 50amp end into your rv cord and get a 30amp plug and 15 amp plug you can plug into campground peristalsis if available giving you 45amps. Not quite the same but a help.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 03-27-2016, 08:36 PM   #16
caper's Avatar
Not all CG allow the 30 and 15 amp plugs. They charge the site for the amperage being used (15, 30 or 50 amp).
Terry and Janet
2007 Ford F150
Old 03-27-2016, 08:43 PM   #17
Bluepill's Avatar
The 50 Amp. is also a "plus" when you go to sell it.
2008 Itasca Meridian 37H
Old 03-27-2016, 08:50 PM   #18
Blackhat6mike's Avatar
If you plan on running anything else while running just one AC, like coffee pot, microwave, water heater, curling iron then a 50amp circuit is a must, not to mention running both AC at once. If you spend time in the south, you WILL run both ACs. Go for the 50 amp.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-28-2016, 03:31 PM   #19
Blog: RVroadtripper.com
hbillsmith's Avatar
Eastlake, Ohio
The two head 45amp solution is iffy. If the post is GFI, it won't work. Just carry a 50 to 30 doggone and if all available is 30, only run one A/C at a time.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 03-28-2016, 05:02 PM   #20
50 amp and 2 ACs is the way to go.
2015 GMC Denali 3500 4X4 Duramax
2015 Cedar Creek 36CKTS (flooded 2-20-18)
2019 Cedar Creek 36CK2 (picked up 5-1-18)
grumpyoldman is offline   Reply With Quote
50 amp
