Old 09-07-2012, 01:38 PM   #1
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
Changing A Tire !!!!!!!
I find it frustrating that the Forest River owner's manual do not recommend a point for jacking a travel trailer (in my case a VIBE 6504) to change a tire.
To add to the frustration here is the reply I received from Forest River when I emailed them for information on how to jack the trailer.
Unfortunately we do not have literature on this and due to liability issues, as a representative of Forest River I am not allowed to make suggestions on what I think you can do in this situation. I am sorry that I cannot help you in this instance.
Darren
pdchristensen is offline   Reply With Quote
Old 09-07-2012, 02:01 PM   #2
TeresaInCAL
TeresaInCAL's Avatar
OMG, if FR can't make a recommendation, then who could? Talk about ridiculous!
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 09-07-2012, 02:02 PM   #3
To add to the insanity, they suggested I contact the tire manufacturer.
Talk about being evasive.
Old 09-07-2012, 02:14 PM   #4
sfrye5853's Avatar
I would look at the frame manufacturer for an expert opinion on where to place the jacks.... That being said, here was a thread regarding jacking the 3150.... Took the Tracer 3150 in for SPIN balancing
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 09-07-2012, 02:42 PM   #5
Great Info
Thanks for the link to the tire rotation photos, however this would apply to a tandem axle. I am dealing with a single axle.
Old 09-07-2012, 02:56 PM   #6
Experienced Newbie
When I jacked up my Apex to check the brakes, I placed a wood block as close to the axle as I could and used a bottle jack to lift it. I have access to a floor jack but wanted to verify the bottle jack's ability as that is what I would be using on the side of the road.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 09-07-2012, 03:15 PM   #7
AquaMan's Avatar
You should be able to put a jack on the axle, close to the wheel, and be able to lift it enough to change a tire, without lifting the other tire off the ground. This also shouldn't put any undue stress on the frame. Changed many trailer tires this way.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-06-2012, 03:18 PM   #8
If I may add 2cents here.
I recently had to repair a tire on a v-cross. I blocked 8" between the two wheels with 2x6 wood then inserted a small Hydraulic piston jack that I keep for odd situations.
just placed it on the underside of the frame in a logical position, and raised it more than enough to get the tire off, and back on.
There is a "drive up" jack sold in CaMping world that is made for this purpose with dual wheel trailers. Prob wont work for single axel.
For Single Axel, I would hook up to a tow vehicle for roll-prevention, and do the same scenario described above. This IS the world of do it yourself, we are on our own.
Forest River is nearly the worst manufacturer I have ever dealt with. Do not look to them for a lot of assistance. Just use your head and be safe.
Dan941 is offline   Reply With Quote
