Old 12-02-2016, 04:55 PM   #1
Dump Valve Vibe 243bhs
In order for me to dump my rear grey tank I have to open the black tank valve. on every other trailer I see if you want to dump the black you open the black and dump close it and open the grey and dump. Just wondering if anyones Vibe is plumbed that way or is mine a mistake from factory.
2016 Vibe Extreme Lite 243bhs
2007 Ford F150
jmkm2804 is offline   Reply With Quote
Old 12-02-2016, 05:26 PM   #2
Hopefully other owners will chime in, but it sounds like a mistake to me. However, since you say it's the rear grey tank (so you can still flush with the front gray tank) that may be why they did it that way.
In any case - be careful. If your black tank is fuller than that rear gray tank, and if you inadvertently open the gray valve, you'll be putting black tank water in the rear grey tank. Not good.
2011 Traverse LT, 3.6L, FWD
Old 12-03-2016, 09:26 AM   #3
I vote mistake.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-11-2016, 06:48 PM   #4
I vote mistake also. The gray rear tank is completely separate in our 268 vibe. The front gray drain is the one we use to flush out the black drain tubing.
Phil & Pat
2017 Vibe 268RKS
2018 Ram 2500
pbbandpab is offline   Reply With Quote
Old 12-14-2016, 08:46 PM   #5
OP: It should work the same as your old trailer. Sounds like a mistake as others have said.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
valve, vibe
