Old 05-08-2011, 08:55 PM   #1
RichnVinny's Avatar
We just got our fifth wheel 305 v ret and we love it
We love our brand new 305V RET fifth wheel
RichnVinny is offline   Reply With Quote
Old 06-01-2011, 10:06 PM   #2
cebaker's Avatar
Nice looking camper. We just got our TT vcross 32vbhs last week. I saw your in the Charlotte area. I'm in the monroe area.
2010 Toyota Tundra
Forest River 32vbhs
cebaker is offline   Reply With Quote
Old 06-02-2011, 01:03 AM   #3
hi..nice rig! You pull that with a 1/2 ton?
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 06-02-2011, 07:08 AM   #4
RichnVinny's Avatar
Yeah the dry weight is under 9k and we have the 2011 F150 lariat with ecoboost and tow package our truck can tow up to 11500 so we are way under
Old 06-02-2011, 07:20 AM   #5
Herk7769's Avatar
What is your pin weight with that unit?
Are you still under the GVW of the truck?
A properly loaded 9,000 pound 5th wheel will require a minimum pin weight of (at the minimum of 15%) 1350 pounds to avoid control problems. (Typicaly truck front end "wallowing" like a boat in swells).
HAM CALLSIGN - KC3FFW
Old 06-02-2011, 09:42 AM   #6
RichnVinny's Avatar
Dry hitch weight is 1900 lbs
Old 06-02-2011, 09:43 AM   #7
RichnVinny's Avatar
1895# to be exact, so far we have not had any problems
Old 06-02-2011, 11:39 AM   #8
Herk7769's Avatar
Rich,
As most anyone will tell you, dry weights mean nothing after it leaves the plant. In fact, it means nothing WHEN it leaves the plant because it does not include weights of options you add when it is built. The UVW (yellow sticker) has the actual Unladen vehicle weight with options installed and will be significantly different than the notional "Dry weight" in the brochure.
The best way to get the real pin load on your truck is to go to CAT (or equivelent) scale and weight the truck and camper loaded for camping (about 10 bucks) (get weights for each axle on the truck) and then drop the camper in the yard and reweigh the truck without the camper hooked up (again with weights on each axle) and subtract the two gross weights. That will give you an actual pin weight and gross weight on the ruck loaded and unloaded.
Old 07-25-2011, 01:35 AM   #9
Greenstonekiwis's Avatar
Hey RichNVinny got any more pics of your new 5th? the 305V RET is one we have on our list of considerations as its has a good GVWR and reasonable tank capacity for full timing.
U are obviously pretty stoked with your unit. They say the V Cross utilises more space - true?
Greenstonekiwis is offline   Reply With Quote
Old 08-04-2011, 09:42 PM   #10
cebaker's Avatar
Headed to White Lake, NC in one week.
Camp Clearwater
2010 Toyota Tundra
Forest River 32vbhs
