Old 06-15-2013, 06:51 PM   #1
tanddc's Avatar
My camping buddy has a new vibe 6502. In my surveyor when I need to top off my fresh water tank I fill a 6 gallon jug and pour it in. We went to top his off tonight and found it only had a hose fitting (like a city water connection). any suggestions long term solutions? Water pump? Change the inlet?
tanddc is offline   Reply With Quote
Old 06-15-2013, 07:18 PM   #2
lowbubba's Avatar
I cut off a section of harder hose. Went to Harbor Freight and purchased their 12 volt water pump. Made up a section of hose to go from pump to container. You can make a long lead to hook to your battery or find something to tap into under the camper. It works very well.
Lowbubba
What could go wrong?
lowbubba is offline   Reply With Quote
Old 06-15-2013, 08:33 PM   #3
Denver, CO
garbonz's Avatar
gotta get a pump if you don't have a hose. i also use one of the flexible bladders that holds 40 gallons as needed.
2017 Fuse 23T
Old 06-17-2013, 11:28 AM   #4
tanddc's Avatar
Thanks for the help. I guess he is stuck getting a pump. Is it normal to have this type of fill?
Old 06-17-2013, 12:37 PM   #5
lowbubba's Avatar
My Surveyor did not, our V Cross does. You may be able to get a new fitting and remove your old and replace and reseal the new one.
Lowbubba
Old 06-17-2013, 01:01 PM   #6
jjm901's Avatar
We had same problem. We purchased this pump from amazon:
http://www.amazon.com/Wayne-PC2-115-...rds=Water+pump
It had good reviews and threaded for hose already.
2013 Ford F150 Super-Crew
2014 Heritage Glen 312qbud
jjm901 is offline   Reply With Quote
Old 06-17-2013, 01:08 PM   #7
tanddc's Avatar
Thanks jjm901, that pump is actually made by the sister company of my employer. It is acutally made in the same building where I work! (Right here in Harrison Ohio). I will have to go next door and check it out. I didn't really think about them for a tranfer pump.
Old 06-17-2013, 01:25 PM   #8
Pump
I used an Attwood aerator pump from Wal-Mart. Same pump they use on boats to keep the bait oxygenated. Under $20.00. I made a long DC wire to plug into my car and got some fittings at Home Depot to make the entire setup for under $30.00. I also purchased a couple of 7 gallon water containers from Wal-Mart to pump out of. Works great and cheap.
Davidceder is offline   Reply With Quote
Old 06-17-2013, 01:31 PM   #9
Gripper's Avatar
Try a drill pump, very inexpensive and just need to carry a drill. With clamps connect a piece of hose with the proper fitting on the one end for the trailer. I use the drill pump on mine along with the 5 gallon blue tanks. Usually keep two full and ready, then simply pump in as needed much easier then pouring.
Essex County
Southern most area in Canada
2015 F150 XLT Sport 5 ltr V8
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
