Old 05-13-2014, 07:52 PM   #21
Blubear's Avatar
Thanks! Will do, but can it wait till after this trip or am I going to do other damage?
Blubear is offline   Reply With Quote
Old 05-13-2014, 07:53 PM   #22
BamaBob's Avatar
Originally Posted by Herk7769 View Post
LOL, where do you think I got them?
When I see something that helps me understand a system, I save it to a thumb drive that has been nicknamed "The Herkbrary" by members of this very forum.
I have just organized everything on the drive by "system" folder. I also have included links to repair resources and YouTube videos.
That drive is now over 40 gigabytes in size (I throw nothing away).
FRF would be ticked if I uploaded all that
I keep it in this thumb drive.
Ok Lou...at Goshen you MUST bring the Herkbrary...I MUST transfer to my MacBook Pro...
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-13-2014, 07:56 PM   #23
Herk7769's Avatar
Damage?
Just use your fresh water tank (filled with your water hose from the campground bib) with your pump and you won't even know you have a problem. Heck, it might even fix your problem if it is crud in the pump's check valve.
If you try to use the city water inlet, water will fill (and possible burst) your fresh water tank to over flowing.
HAM CALLSIGN - KC3FFW
Old 05-13-2014, 07:57 PM   #24
Herk7769's Avatar
I go nowhere without it...
Old 05-13-2014, 07:58 PM   #25
BamaBob's Avatar
You.Are.THE.Man!
Old 05-13-2014, 08:03 PM   #26
TheChockleys's Avatar
Ok so here's a new situation today I went out to flush my black tank and when I hooked up to my black tank flush. .. My fresh water tank indicated that it was filling up also!!!! It's there any way that it could my panel indicating incorrectly? I'm pretty upset right now with this new purchase. Maybe I should have just bought a boat. Lol
TheChockleys is offline   Reply With Quote
Old 05-13-2014, 08:12 PM   #27
VinceU's Avatar
All depends if the black tank dump was open or not. Could be the indicator you were looking out is connected to the black tank. If so it would fill slowly while the flush is open.
Old 05-13-2014, 09:00 PM   #28
Blubear's Avatar
Will do & thanks for the guidance Here..
Sent from my SCH-I535 using Forest River Forums mobile app
Old 05-13-2014, 09:02 PM   #29
Herk7769's Avatar
If the sensor are not wired correctly at the monitor, the black tank sensors could be reporting on the fresh water tank.
If you fill the fresh water tank, does the black tank register?
Here is the wiring diagram for the system.
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 17 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 13 views)
Old 05-13-2014, 09:22 PM   #30
BamaBob's Avatar
OK this is a SERIOUS EWWWW. Something is very VERY wrong with your plumbing. If this is indeed happening, you need to return this unit to the dealer - In fact I would go so far as to contact FR Corporate
fresh water, led, water
