Old 01-02-2016, 08:43 AM   #1
Furnace questions on 268RKS
Just used my furnace for the first time this week and when the trailer is plugged into shore power the whole roof unit turns on along with the floor vent when the furnace is turned on. it's louder than hell and ends up blowing cold air out the ceiling vents. When it's running on 12v the roof unit stays off and just the furnace fan and floor vents are on. Seems to work just as well if not better and is completely quiet. Is there any way to keep the roof unit off when plugged into AC power? I know it's probably trying to recirculate air or something but it's insanely loud and creates a wicked draft of cold air
mopar04 is offline   Reply With Quote
Old 01-02-2016, 10:55 AM   #2
fonzie's Avatar
Put your thermostat to "auto".....see manual starting page 7.....
File Type: pdf Dometic Thermostat- Single Zone Digital.pdf (1.40 MB, 56 views)
Fonzie
Old 01-02-2016, 11:03 AM   #3
X2
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 01-04-2016, 07:57 AM   #4
Yes, what fonzie said.. when running the furnace, set the thermostat fan setting on auto. When running the AC, keep the fan setting on lo or hi. I have not had my Vibe in heat yet, but on my last rig I noticed the AC coils would freeze over when I had the AC on Auto.
southpaw821 is offline   Reply With Quote
Old 01-04-2016, 08:40 AM   #5
Thanks everyone, works perfect now. I assumed Fan was just a setting to recirculate air when neither heat or cool was on
Old 01-05-2016, 10:57 AM   #6
Wingdreamer's Avatar
If you are finding a strong blast of air coming from the main vent on the roof a/c, not sure if you are aware that you can slide the roof vent "closed" on the ceiling. This will redirect the air flow to the other ceiling vents on the ceiling. Didnt know if you were aware of this white plastic slide vent...
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
furnace
