Old 11-09-2017, 10:41 AM   #1
Greasing wheel bearings 268RKS
Hi all!
We have had our Vibe 1 1/2 years- and think it's time to grease the wheel bearings. Has anybody out there greased their wheel bearings yet? If so, how do you do it?
Thank you!
Cyndi
Cyndi is offline   Reply With Quote
Old 11-09-2017, 12:55 PM   #2
Good info here: http://www.timken.com/pdf/10844_MDV2...Wheel-Ends.pdf
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 11-09-2017, 01:08 PM   #3
Thank you Mars!!! Appreciate your help!
Old 11-09-2017, 01:40 PM   #4
Do you grease based on time passed or number of miles driven?
Hawkeye1558 is offline   Reply With Quote
Old 11-09-2017, 01:45 PM   #5
Here is a forum search on greasing wheel bearings.
Plenty of past discussion on this subject and MANY opinions!
Greasing Wheel Bearings
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 11-09-2017, 01:50 PM   #6
clr
I remove the wheel and check the bearing and repack them as well as replace the grease seal every other year. On the odd year I just give them a quick visual check.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 11-09-2017, 02:08 PM   #7
Thanks all for the info!!! Love this forum- so many helpful fellow campers out there!! Much appreciated!
Old 11-10-2017, 02:53 PM   #8
TimVWulp's Avatar
You need to be careful which type of grease you mix together. Dexter recommends that you use a lithium based complex grease. If you mix other types with lithium grease they may or will react with each other and cause the grease to fail. Many of the grease manufactures produce a lithium based grease you just need to make sure it's lithium based. If you can't find lithium based grease check with your local auto store.
I have attached a link from the site library at the top of this page. You will need to download the link and then open it. On page 21 you will find what Dexter recommends to use.
Google mixing greases you will learn what the grease manufactures have to say about doing this.
I pulled my brake drum off to repack the bearings for the first time this fall and found that 3 of the grease seals had failed and let grease into the breaks. I foolishly did add grease with the grease zerk to the bearings. It was only 2 or 3 pumps of grease. There was already way to much grease in the bearings this just made it worse. I will just clean and repack the bearings every 3 year or 12,000 miles by hand and never use the zerk again.
http://www.forestriverforums.com/for...?do=file&id=72
Hope this is helpful Tim
TimVWulp is offline   Reply With Quote
Old 11-10-2017, 04:37 PM   #9
Thank you Tim!!! Very helpful!!!
Old 11-12-2017, 11:31 AM   #10
Evereddie's Avatar
Originally Posted by TimVWulp View Post
I am following this thread. BTW, this link does not work. What was it?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
bearings, wheel
