Old 05-10-2016, 07:49 AM   #1
Grill on the back of a 308BHS
My 308BHS has a grill on the back mounted to the bumper.
We use the thing all the time.
We picked up the trailer April 15 and the grill was just replaced under Warranty because it rusted out even through we kept the cover on it.
Any ideas on how to prevent this or who make the grill so I can purchase a spare one. There a no marking on it at all that I can see.
rwasmith is offline   Reply With Quote
Old 05-11-2016, 11:49 AM   #2
fireman1317's Avatar
Sorry, I don't have an answer for you. You said you use your grill all the time. What is the trick for keeping the area under the grill grate clean and how do you manage grease?
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 05-11-2016, 12:24 PM   #3
That is something I need to figure out. I believe that is what killed my grill. As you know it would just collect grease.
I was thinking of spraying it with layers of PAM.
Not sure if that works but I need it to last longer than 1 year
Old 05-11-2016, 08:23 PM   #4
BigHomey's Avatar
The 268RKS comes with this grill. Sorry, can't help you with the rust problem.
Sidekick Grill - Fleming Sales Co Inc RVAD400 - Gas Grills - Camping World
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 45th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is online now   Reply With Quote
Old 05-12-2016, 12:19 PM   #5
Thanks BigHomey.. I think I will just buy one to have in stock.
Old 05-12-2016, 12:37 PM   #6
ccsvolsfan's Avatar
Bought a ss grill, drilled out rivets on old grill brackets, re-attached the brackets to ss grill, no more rust. Just make sure width is same.
ccsvolsfan is offline   Reply With Quote
Old 05-12-2016, 12:58 PM   #7
BigHomey's Avatar
What grill did you find that fit on the grill platform? I have not found one yet.
1997 F-350 CC PSD
Old 05-12-2016, 01:23 PM   #8
ccsvolsfan's Avatar
It was an Olympian 5500 by Camco. Because the burner plate is cast iron, I sometimes put Al foil on it and use with charcoal. Indirect heat method. The original cover works also.
Old 05-16-2016, 01:03 PM   #9
Toolman_GA's Avatar
Vibe Gas Grill Information
We purchased a 2017 268rks and it came with a Gas Grill from National Supply: Model #YH1801RV-1. 1-574-295-9200. It it attached to a stanchion that is bolted to the rear bumper and swings around to use with the outside kitchen. I attached a PDF file with a picture and details. We love it. Yes, I can understand that it will probably rust out quickly as it is very light weight steel; however, like you I would not complain about having to replace it periodically.
Good luck!
Toolman_GA is offline   Reply With Quote
Old 05-16-2016, 02:04 PM   #10
I would agree that's the same grill on all those bumper mount units. If you spray on couple of cans of BBQ paint inside and out you might get a couple of years out of it.
We used ours for the first time this weekend. It was already rusty. The grill itself is very cheap, a $20 disposable unit. The bracket seems to be well made and I will try to do like most and adapt a decent grill to it.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
