Old 11-01-2015, 08:33 PM   #1
Heat ducts
We have a 30vsk. There are 4 heat ducts in the floor. There are 3 hoses running under floor. Only 2 heat ducts flow heated air. Is this normal or proper? It don't seem right to me. How is your similar trailer set up?
bowebow is offline   Reply With Quote
Old 11-02-2015, 08:23 AM   #2
Head Rambler
I assume by heat ducts in the floor you mean registers. If that's the case then they all should have warm air flowing from them when the furnace is on. The ones closer to the furnace will flow more air but they all should flow some.
The three hoses are the ducts and one of them probably feeds the 4 registers and the other ones probably feed the bed and bath rooms. At least that's how it is on the RV we have now.
Gotta go campin!
Old 11-03-2015, 08:06 AM   #3
Thank you. I ment registers.
Old 11-03-2015, 08:37 AM   #4
Head Rambler
You can take a shop vac, remove the registers and see if you can get it to suck air through each floor opening to the others. That may tell you if the duct is blocked between two or more registers.
Gotta go campin!
Old 11-05-2015, 09:33 AM   #5
The bath and rear living room hose flopps like its not connected. When I disconnect hose from furnace I can tell difference in air flow at registers. My logic is not understanding what they were trying to accomplish ? I don't want to mess with the underbelly cover, if I don't have to.
Old 11-05-2015, 09:49 AM   #6
Flybob's Avatar
Check the diameter of the ducts that are not flowing well. In my unit the ducts going to the bedroom ( longest run) are only 2" diameter and have less flow than the larger ones going to main area and bathroom. Also if possible using mirror or lighted pipe scope, check for restrictions. I had several areas where the ducts were crushed by structure and electrical wiring being pulled too tight across them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-05-2015, 12:25 PM   #7
Head Rambler
Like Flybob, the duct going to the bedroom register is 2" and so is the one going to the bath. They're the longest runs in the RV.
If you have the 'heated' underbelly then all they do is run an open ended duct under there near the tanks and let it flow. That could be one of the 2" ducts you see.
About the only thing they were trying to accomplish was to run it as cheaply as possible. That's why all four registers are hooked to one 3" duct.
Gotta go campin!
Old 11-26-2015, 12:13 PM   #8
I have the V-Cross Vibe 5th wheel. 2014. The heat ducting, 4 inch aluminum foil dryer vent type, was completely crushed on installation. I had to cut access panels in the cardboard under the camper and reroute the heat to a new register in the center of the dining area. I came right out if the heater and over the adjoining hot water tank and down into the floor and then over about 3 feet to a new register, using semi-rigid ducting. I now have WONDERFUL heat.
hiker108 is offline   Reply With Quote
Old 12-25-2015, 10:42 PM   #9
I have registers in living room, kitchen, bedroom and bathroom. All registers have warm air with the furnace on. Yours should as well.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 01-26-2016, 11:12 PM   #10
Wingdreamer's Avatar
Dealer found similar issue with my ducting... all bunched up and kinked. He removed 5 feet of surplus ducting that was causing it to bunch up, now much better flow. Had to be done in the heated underbelly...
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
