Originally Posted by wz3mo
My 2016 268RKS dinette doesn't make into a bed. The table top will come off but the spacing between the seating is too far apart for the table to lay across to make a bed.
I would be contacting the dealer regarding that, because that's a manufacturing flaw. I have the same trailer and mine works. Worst case if it's out of warranty, you could glue and screw a length of 2×3 down each side where the skinny little strips are. Should do the trick.
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
