Old 05-26-2012, 09:24 PM   #1
Location for Manual slide for Vibe 6502
Does anyone know where I find the bolt for the manual slide for this model? The owners manual tells you the process... but not the location.
Thanks,
kblack is offline   Reply With Quote
Old 06-03-2012, 12:34 PM   #2
I have looked for the manual crank for the slide also. I may have to contact the dealer.
Tim
AstronomyGuy is offline   Reply With Quote
Old 06-05-2012, 10:50 AM   #3
The owners manual for the new V-Cross 5er that I picked up on February 17, 2012 was of little help for anything, it is to general and must have been compiled to go with a lot of different trailers.
whj77372 is offline   Reply With Quote
Old 06-05-2012, 11:05 AM   #4
Triguy's Avatar
Kblack,
Who is the manufacturer of your slideout system? I've included a manual for the Lippert Electric just in case that is yours. You can download it in our Files section.
Let me know if it isn't a Lippert Electric. I might have the manual for a different system.
Here's a picture of my motor, which has an in-frame design (some are through the frame or located under a sofa, etc). You can see that you can use the hand crank, ratchet or a drill with a 3/4" socket to manually extend and retract.
Name:	slideout mechanism.jpg
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-05-2012, 11:06 AM   #5
HB just fixed one and he found the bolt at a local lumber yard so may want to check there.
jmswms is offline   Reply With Quote
