Old 08-22-2015, 09:43 PM   #1
Look what I found
While doing some routine matinance on our vibe I happened to notice a plastic cover in my awning arm track front of camper slide it up and behold a hole where any water could pour right in
Name:   ImageUploadedByForest River Forums1440297747.212278.jpg
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 08-28-2015, 12:06 PM   #2
wz3mo's Avatar
Originally Posted by timothy clancy View Post
While doing some routine matinance on our vibe I happened to notice a plastic cover in my awning arm track front of camper slide it up and behold a hole where any water could pour right in Attachment 86553
Clancy vibe272bhs
WOW, good thing you found that! Mine doesn't have a cover(?) but is well filled with silicone.
wz3mo is offline   Reply With Quote
Old 08-28-2015, 12:22 PM   #3
dcheatwood's Avatar
Good find. Makes you want to look for more. My sofa leg punched through the floor and when I pulled the sofa out from the wall I found 2 huge holes cut through the floor in the rear corners where wiring and fresh water hose came through. I could see the ground. Enough space for a squirrel to enter. I got a can of expanding foam and filled them in. Then hunted down and filled several more smaller ones.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
