Old 04-19-2016, 11:04 AM   #1
fireman1317's Avatar
Low point drain valves on 315BHK
Does anyone know where the valves are for the low point drains on a 315BHK?
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 04-19-2016, 11:34 AM   #2
AquaMan's Avatar
Provided you camper has valves, they would likely be just above wherever the hoses come out the bottom. May have to remove an access panel. Most low point drains just have caps on the hoses that you take off and let drain.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-21-2016, 08:37 PM   #3
I have not found any low point drains yet. I believe the two blue lines by the fresh water tank drain are the overflow and an air relief for the fresh water tank. The reason I think this is because when you fill the tank you can hear air coming out of them and then water pours out of them when the tank is full. If you find the drains please post a picture of them, I will do the same.
2016 Vibe Extreme Lite 315BHK
2006 F150 Supercrew 4x4
zexel is offline   Reply With Quote
Old 05-04-2016, 09:22 AM   #4
Dave53's Avatar
Mine are near the driver side rear of the trailer. There is a sticker on the trailer saying low point drains. Mine are up underneath the skirt and not visible from the side. There are 2 drain tunes with caps on them. There is also a drain valve for your freak water tank. Also indicated with a sticker.
2016 Vibe Extreme Lite 221 RBS
2013 Silverado 2500 HD Duramax
Dave53 is offline   Reply With Quote
Old 05-04-2016, 06:02 PM   #5
On my 315BHK the low point drains are located about two feet forward from the outside kitchen down by the frame. A red and a blue line with caps you remove to drain the lines.
Old 05-05-2016, 03:43 PM   #6
Thanks. I will have to look specifically for that.
Old 05-09-2016, 01:26 PM   #7
I was looking for mine as well over the weekend in on my 272.. but didn't find any
southpaw821 is offline   Reply With Quote
Old 05-09-2016, 02:07 PM   #8
KAS
Low Point Drain Shut-Off Valves
zexel
I have a similar setup, just 2 screw-on caps on my low point drain hoses. Has anyone added shutoff valves? I am trying to find some that just screw onto the drain hoses and then use the existing caps at the bottom of the valves to seal the openings. I haven't been able to find any of that type on any website (the ones I find are either clamp-on, angled, or the wrong size). My idea is similar to the ones on the picture, except that the valves should be at the ends of the hoses w/o extensions. I have checked several RV websites and Amazon, but no luck so far!
KAS is offline   Reply With Quote
Old 05-10-2016, 02:07 PM   #9
Being that the drain lines are PEX , you could just use Sharkbite type valves. Can be found at any hardware store.
Old 05-10-2016, 02:40 PM   #10
Iwannacamp's Avatar
Originally Posted by KAS View Post
zexel
It should be 1/2" MPT on the tubes. Fpt ball valves and 1/2 PVC plugs... Or a MxF valve....or cut the line and put a pex style(of your connection choice) on the line.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
drain, valve
