Melting lights...?!
Owner of a 308bhs. I've had one of the two bulbs short out thru out the camper here and there, nothing too bad or annoying. The problem, came when one of the two in the bathroom went out. When I went to swap it out, I noticed that where the actual bulb plugs into the connection was melted/disformed. Because of lack of time, I haven't researched the cause, nor have I replaced. But now the other side went out and was also melted. The second one was left on (unintentionally) for about ~13 hours. Even though 13 hours is a while, I wouldn't think that that would be acceptable in the design or configuration of the light fixtures.
Anyone else have this issue or recommend where to get a replacement fixture...? Thank you
