11-03-2012, 02:07 PM
Need More Info
just got the trailer back from repair yesterday and the battery was dead. i guess i need to disconnect it next time. when i boosted it, the furnace came on and an alarm was beeping intermittently. is there something else to shut off when not in use or what is going on? thanks
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
11-03-2012, 02:14 PM
good questions. we turn our furnace off when traveling, but what was the alarm? HUM, hope someone adds some answers...
11-03-2012, 02:20 PM
Probably the CO2 alarm. Charge the battery and see if it doesn't shut off.
11-03-2012, 02:46 PM
ya, probably low battery making it go off. why was the furnace running? is there another shutoff besides turning the thermostat down?
2004 Dodge Dakota
11-03-2012, 04:57 PM
something is still beeping with the battery disconnected
2004 Dodge Dakota
11-04-2012, 04:01 PM
beeping was the smoke detector, i thought it was ac powered but the battery was low because it was cold. the furnace still runs when i connect the battery.
2004 Dodge Dakota
11-04-2012, 04:34 PM
I am thinking something is wrong at the thermostat like a short..or low level setting..??
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
11-04-2012, 04:48 PM
Based on an assumed location, wonder if the shop was running the heater to keep it comfy, used up your battery and never said anything! Is your propane level lower?
11-04-2012, 04:52 PM
my propane is off, and it is cold here. it is colder than the thermostat goes. i need to shut it off some other way
2004 Dodge Dakota
11-04-2012, 04:58 PM
Somethimes there's a select switch on the side of the thermostat for cool/furnace/off. Otherwise pull the 15 amp fuse in your DC power panel.
11-04-2012, 05:01 PM
no switch that i can see. i thought of pulling the fuse but i thought i was missing another way
2004 Dodge Dakota
11-04-2012, 05:20 PM
Maybe its available, I found a similar tt in a Vermont ad. I could zoom into the tank monitor and thermostat. It appears it has the temp control at the top and two or three switches at the bottom. Can't make out the name though. Have never seen any camper with heat and ac without a select for needed appliance, really weird. Maybe thats why this tt had mandatory ac and heater. Never saw any other cutout for that reason.
11-04-2012, 05:22 PM
I am with Vince...pull the fuse..!
Make sure you put is somewhere when it comes time to put it back you know that you have pulled it and what the amp was...not sure about you but my mind is great .....just in short periods....lol
11-04-2012, 05:33 PM
the tank monitor has the water heater switch and the pump switch but i can't see any other. i guess the fuse is next. thanks
2004 Dodge Dakota
11-21-2012, 12:12 PM
i put a little lamp switch right beside the thermostat and opened the thermostat lead. the furnace thinks it is shut off.
2004 Dodge Dakota
