Old 11-03-2012, 02:07 PM   #1
Need More Info
just got the trailer back from repair yesterday and the battery was dead. i guess i need to disconnect it next time. when i boosted it, the furnace came on and an alarm was beeping intermittently. is there something else to shut off when not in use or what is going on? thanks
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
dbuzz77 is offline   Reply With Quote
Old 11-03-2012, 02:14 PM   #2
good questions. we turn our furnace off when traveling, but what was the alarm? HUM, hope someone adds some answers...
ritzyteach is offline   Reply With Quote
Old 11-03-2012, 02:20 PM   #3
Probably the CO2 alarm. Charge the battery and see if it doesn't shut off.
Old 11-03-2012, 02:46 PM   #4
ya, probably low battery making it go off. why was the furnace running? is there another shutoff besides turning the thermostat down?
2004 Dodge Dakota
Old 11-03-2012, 04:57 PM   #5
something is still beeping with the battery disconnected
2004 Dodge Dakota
Old 11-04-2012, 03:01 PM   #6
beeping was the smoke detector, i thought it was ac powered but the battery was low because it was cold. the furnace still runs when i connect the battery.
2004 Dodge Dakota
Old 11-04-2012, 03:34 PM   #7
puff's Avatar
I am thinking something is wrong at the thermostat like a short..or low level setting..??
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 11-04-2012, 03:48 PM   #8
VinceU's Avatar
Based on an assumed location, wonder if the shop was running the heater to keep it comfy, used up your battery and never said anything! Is your propane level lower?
Old 11-04-2012, 03:52 PM   #9
my propane is off, and it is cold here. it is colder than the thermostat goes. i need to shut it off some other way
2004 Dodge Dakota
Old 11-04-2012, 03:58 PM   #10
VinceU's Avatar
Somethimes there's a select switch on the side of the thermostat for cool/furnace/off. Otherwise pull the 15 amp fuse in your DC power panel.
