Old 04-11-2011, 05:26 PM   #11
old guys's Avatar
Welcome from Ontario Canada. Sorry I didn't see this post earlier but I have been a tad busy. Nice work on the wheel chocks. We only use the plastic storebought type but that looks like a much better system. Don't tell my wife or I will have more to do. Anyway, glad to have you here and keep the ideas coming. it is nice to see other people's ideas at work. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
Old 05-11-2011, 08:46 AM   #12
Hi my name is Greg. I just purchased 2012 30wfkss. I am trading in 36 foot class A. This is the first TT I have owned. I noticed in old guys reply his picture had what looks like a chevy avalanche pulling his v cross. Just wondering what size trailer. And what kind of hitch he is using. I have a 2002 chevy avalanche z71. 4wd with 5.3 L v8. I am not worried about trailer weight. It's within limits. But I am worried about tongue weight.
Greg Wood is offline   Reply With Quote
Old 05-11-2011, 09:20 AM   #13
Big Dawg's Avatar
Welcome to the site. I like the chocks you built. I just built a set myself this past weekend. They do make a difference in the movement of the camper.
Greg Wood, you will need to look into a WDH W/Sway control, it makes all the difference in the world. Get one that fit's the tongue weight of the TT. You should be able to find that info on the TT.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 05-11-2011, 12:49 PM   #14
Thank you for the information. The dealer said that they will set my truck up to be safe to pull it. But would like to know myself before they install anything.
Old 05-11-2011, 08:50 PM   #15
old guys's Avatar
Hi Greg. It is a 2007 Avalanche LT, 4wd., 5.3 liter with (if I remember correctly) 373 gears in the rear. We tow a 27vfks v-cross with a door sticker that says the trailers dry weight is 5738 lbs. and we use a 10,000 lb equalizer four point weight distributing hitch. This hitch has built in sway control. We have towed the trailer from Ontario Canada to Florida and also to the Maritime Provinces via the Gaspe region of Quebec. We had to have the rear end rebuilt on the way back from Nova Scotia but that was because the pinion bearing broke and went into the differential. It was all under warranty and they said it wasn't caused by the trailer as we were at least 1500 lbs under max. gcvw. We have just returned from Branson and averaged 9mph. going against strong winds and a more usual 10mph. coming home with little wind. The trailer behaved quite well as far as sway goes, even in gusty winds, so I guess the built in sway control works okay. We are quite happy with our Equalizer but your dealer may not handle them. We were originally looking for a Centreline Hitch by Husky but we bought in the U.S. and they did not handle that brand. They work on a torsion bar system as well but are a fair bit more expensive so for us it saved us money and worked out well. Good luck with whatever you chose. Old Guys
Old 05-11-2011, 09:18 PM   #16
HondoPatrick's Avatar
Welcome to the forum and congrats on the new trailer. Hope you have a great camping season!
HondoPatrick
2012 Ford F250 Lariat FX4
2012 LaCrosse 318BHS w/4 Point Equal-i-zer Hitch
2 Wilderness Systems Kayaks
Nights Spent Camping in 2011 (19), 2012 (16)
http://www.armadillotimes.com
HondoPatrick is offline   Reply With Quote
Old 05-12-2011, 04:14 AM   #17
Thanks old guys. That was the information that I was needing. My truck is built the same and the dealer is recommending a 10,000 lb wdh with sway control. I live in southern Missouri so if you just left Branson you know the kind of hills I will be pulling through. I was kind of worried about getting a TT. Always had a class A. But we really do like this V cross. Thanks again for all of the information. Greg
Old 05-21-2011, 06:24 AM   #18
Thanks old guys for the help. Brought our trailer home yesterday and it pulled great with the hitch they set me up with. WDH with anti-sway with 1200 lb bars. I was kind of worried at first. But had no problem at all. Think we are going to love it. Doubt I will ever go back to a class A.
Old 05-21-2011, 09:58 AM   #19
*** Update ***
We had the new trailer out on her maiden voyage last weekend. No surprises, everything worked well and the Wife really appreciated the bathroom (we've always had tent trailers before). This trailer is defiantly the biggest trailer I've towed before so that was a bit of new experience. We had some very stiff winds driving down to the park and back, and had some observations. With the fresh water tank full (which sits behind the axles) the trailer had some sway in the 40-50 Km/h gusts, but nothing unmanageable. Towing home with the tank empty cut the swaying in half.
After some consideration, and calculating the number of hours we'll eventually have towing this trailer, we decided a WD hitch that has great sway control will be a worthy investment. I picked up a Reese Pro SC 800 on Friday and will attempt the install over the weekend. I've heard nothing but good about this hitch and am looking forward to the results! I'll try to remember to take some pictures and post another thread of the install.
A small story of our trip down of my forgetfulness: When changing highways on our way down to the park, I pulled over to do a quick walk around the truck and trailer, checking for loose doors, tire heat, light re-check, just a quick once over. When I got around to the TT door, I noticed water dripping from under the door. I know I didn't turn the pump on but was concerned about the source of the leak. When I got in the trailer water was everywhere on the floor, thankfully the entire trailer is lino. After checking under the sinks and not finding the source of the water, I glanced over at the cooler on the floor and new instantly what had happened. The ice was melting and I forgot to close the drain plug on the cooler!!! The wife and I quickly mopped up the water and were on our way again........laughing at my forgetfulness!
RancheroMan is offline   Reply With Quote
Old 05-21-2011, 10:48 AM   #20
BOBFIDY's Avatar
Hi Greg and welcome to the forum.
Yes...OLD GUYS was one of the fine folks at the 1st FROG Rally in Branson a few weeks ago.
There are 3 of us FROGS here in the NE Oklahoma area and are planning an outing June 8 to 12 at MarVal RV Resort near Gore, Ok. and another outing at Natural Falls State Park near West Siloam Springs, Ok. in July.
If you can...please join us at either or both outings.
BOB
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
« Alarm | 245vrd »
