Originally Posted by mattstacie
If you are hooked up to shore power and not using propane to heat with, is the water heater switch supposed to be off?
Yes, if you have the electric option to heat your water heater, the switch on your panel should be off.
You have to go outside to turn the electric portion on to heat the water heater on most models.
